Can entangled particles communicate through time?
  • Thread starter Jim White
  • Tags
    Wormhole
In summary, a thought experiment involving entangled particles was discussed. One particle was placed in a time capsule for a million years while the other was taken on a high-speed train around the Earth for the same amount of time. When both particles were stopped at a predetermined point, there was no way for the chrono-naught to pass a message to the other particle via entanglement alone. This is due to the no-signalling theorem, which states that there is no measurement in quantum mechanics that can determine if a particle is entangled or not. The concept of entanglement and its limitations were further explored in the conversation.
Jim White
Thought experiment; You entangle a pair of particles. a chrono-naught takes one half of the pair and gets into Eisenstein's train, which now encircles the earth, and is then accelerated to .999 the speed of light and continues around the Earth for a million years or so. the other half of the entangled pair is placed in a time capsule and sealed for a million years or so. An observer on the moon would see a pair of entangled particles, one racing around the planet, the other sitting in a box. The chrono-naught would have slowed his passage through time, while the particle in the box would have experienced normal time passage. (relative to each other) But what happens when both particles are stopped at a predetermined point in time set by the time capsule box and then a message is passed from the chrono-naught VIA the entangled particle to the other particle in the box? Is the past talking to the future?
The short answer is that the chrono-naught cannot pass any massage via entanglement alone.
If you look at a particle by itself, there is no way of knowing if it is half of an entangled pair or not. There is no measurement (as far as Quantum mechanics can tell us) that could ever tell you this either. If there was, then you could communicate via entanglement, but because there isn't you can't.
If you're curious how we can know this, and you'd like to look it up, I think it's called the no-signalling theorem.
Interesting scenario, though.
1. What is entanglement?
Entanglement is a phenomenon in quantum mechanics where two or more particles become correlated in such a way that the state of one particle cannot be described without considering the state of the other particle(s). This correlation exists even if the particles are separated by large distances.
2. How does entanglement relate to wormholes?
Some theories suggest that entanglement could be used to create a type of wormhole, also known as an Einstein-Rosen bridge. This would allow for instantaneous communication or travel between two distant points in space, without actually physically traveling through the space in between.
3. Can entanglement be used for time travel?
There is currently no evidence to suggest that entanglement can be used for time travel. The concept of time travel involves many complex theories and it is not yet clear how entanglement could play a role in this.
4. Are there any practical applications for entanglement and wormholes?
While the idea of using entanglement to create wormholes is still purely theoretical, entanglement itself has many practical applications in areas such as quantum computing, cryptography, and teleportation.
5. Is entanglement a proven phenomenon?
Yes, entanglement has been proven through numerous experiments and is an accepted concept in quantum mechanics. However, the idea of using entanglement to create wormholes is still a topic of ongoing research and is not yet fully understood or proven.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
