Can Entropy Be Reduced in a Spontaneous Thermodynamic Process?
  • Thread starter Thread starter jornrune
    Expansion
The discussion revolves around a thermodynamic scenario involving a small chamber of H2O gas and an infinitely large reservoir of H2O gas. When the valve is opened, the gases mix until they reach equilibrium at 1 bar, with the properties expected to be 1.0 Bar, 7.9 kJ/(kg*K), 220C, and 2900 kJ/kg. The participant questions whether this process, which appears to lower entropy, aligns with the second law of thermodynamics. They emphasize that since the pressure is dictated by the infinite source, there seems to be no alternative outcomes, leading to a potential contradiction in thermodynamic principles. The inquiry seeks clarity on whether enthalpy or temperature changes could explain the observed results.
jornrune
Hi! I have a practical problem that causes me to wonder. It seems like I have to choose from gaining energy from nothing, or to get a reduction in entropy from a spontaneous process.
Imagine a small enclosed chamber filled with dry H2O gas. The properties are:
0.5 Bar
8.0 kJ/(kg*K)
200C
2850kJ/kg
An infinitely large reservoir of H2O gas has the following properties:
1.0 Bar
8.0kJ/(kg*K)
240C
2950kJ/kg
Here is a reference chart:
http://www.steamtablesonline.com/images/steam tables p-h diagram (large).png
A valve between the large reservoir and the small chamber is opened and the two gasses are mixed until they reach equilibrium inside the chamber and the pressure is stabilized at 1 bar. Am I correct in assuming that no work has been done and that the properties will be as follows?:
1.0 Bar
7.9kJ/(kg*K)
220C
2900kJ/kg
This seems to be correct as far as temperature and pressure goes. It also seems to add up with the enthalpy as the process is thought to be adiabatic. However, the entropy is lowered, and the process seems to be a so called spontaneous process. The question is if this goes along with the second law of thermodynamics. (It can be read here if you need it refreshed: http://en.wikipedia.org/wiki/Second_law_of_thermodynamics)
Also, I see no room for different results. The pressure is given by the infinite source. This means we can not leave the 1 bar line. There is no way we can get any condensation, so we have the following options:
1: The entropy is actually reduced
2: Enthalpy is lost or gained, and so is temperature
...or am I overlooking something here?
Thanks for any response!
Science news on Phys.org
If you open up the valve and wait for equilibrium, the gas inside your small chamber will be identical to the one in the large reservoir.
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
