Determining Delta S of Cl2 + Br2 --> 2BrCl
  • Thread starter qwexor
  • Tags
    Delta
In summary, Nick explains that to determine whether the change in entropy is positive or negative, you need to determine the difference in entropy between the two sides of the equation.
qwexor
Hello Everyone,
I'm reviewing for my chem 12 midterm and just came across a question that I'm not sure about. If I have the following Reaction:
Cl2(g) + Br2(g) <---> 2BrCl (g)
How can i determine whether the change in entropy (Delta S), is positive or negative.
Thanks!,
Nick
Chemistry news on Phys.org
you can look up the entropy values for each substance and then find the difference between the two sides to find the change in entropy.
Well which side will have the higher entropy? That is the first question.
I think:The left side will have a higher entropy than the right side because there are more possible arrangments for the molecules on the left hand side than there are on the right hand side (as this is just one compound).
I, therefore, think it is negative because the entropy has decreased.
(in white so that qwexor has the option of looking or not).
The Bob (2004 ©)
Your are thinking way too hard. Do like bob said. How many different molecules do you have on the left side of the equation? How many different molecules are on the right side of the equation. 2 on the left and 1 on the right, therefore entropy has decreased. See how easy that was? Don't let your education interfere with your intelligence.
The above solutions work best if you exclude [itex]\Delta S _{mixing} [/itex] which may be of the same order, though opposite sign as [itex]\Delta S _{reaction} [/itex].
There seems to be two molecules for two molecules, as the right has the coefficient of 2. The molar ratio of products to ratio is the same. For this problem you might need to browse through the standard entropy values. It might be the case that the reactant side, entropy is zero. I'll have to read up more.
1. What is the equation for determining Delta S of Cl2 + Br2 --> 2BrCl?
The equation for determining Delta S of Cl2 + Br2 --> 2BrCl is ΔS = ΣnΔS(products) - ΣnΔS(reactants), where n represents the coefficients of each substance in the balanced chemical equation.
2. How do I calculate the Delta S value for each substance in the equation?
The Delta S value for each substance can be calculated using the formula ΔS = nRln(Vf/Vi), where n represents the number of moles, R is the gas constant, Vf is the final volume, and Vi is the initial volume.
3. What is the unit of measurement for Delta S?
The unit of measurement for Delta S is joules per mole per kelvin (J/mol*K).
4. Can Delta S be negative or only positive?
Delta S can be both positive and negative. A positive Delta S value indicates an increase in disorder, while a negative Delta S value indicates a decrease in disorder.
5. Are there any factors that can affect the Delta S value?
Yes, there are several factors that can affect the Delta S value, including changes in temperature, pressure, and the number of moles of substances present in the reaction. Additionally, the physical state of the substances (solid, liquid, gas) can also impact the Delta S value.
  • Thermodynamics
