Entropy Generation Homework: 100kPa-500kPa, 300K-500K, 600K
  • Thread starter Thread starter albertov123
    Entropy Generation
The discussion centers on calculating work and entropy generation for air being compressed and heated in a thermodynamic process. The process includes reversible adiabatic compression from 100 kPa, 300 K to 500 kPa, 475 K, followed by internally reversible isobaric heating to 500 K. Participants share calculations for work done during both steps, with specific values for volume and heat transfer. There is confusion regarding the correct application of the first law of thermodynamics, particularly in accounting for boundary work and heat exchange with the reservoir. Ultimately, the conversation emphasizes the importance of correctly applying thermodynamic principles to avoid negative entropy generation results.
albertov123
Air at 100 kPa, 300 K is to be delivered to a pipeline at 500 kPa, 500 K. The scheme involves reversible adiabatic compression of the air and then internally reversible isobaric heating. Assume that, heat is exchanged with a reservoir at 600 K.
Determine the work and entropy generation.
v = RT/P
[/B]
  • For the reversible adiabatic compression part. (Between 1-2)
I have found both the work and the entropy generation.
  • For the internally reversible isobaric heating (Between 2-3)
I have found boundary work from PdV but I'm not clear on how to find the entropy generation for this heating process.
I'm interested in what you got for the entropy change in the adiabatic reversible compression. Do you know the general equation for the entropy change of an ideal gas between two thermodynamic equilibrium states? Please show your work for step 2 also.
Chet
v1 = 0.861 m3/kgFrom T2/T1 = (P2/P1)(k-1)/k
T2 = 475.15 K- W = U = cv (T2-T1) W = - 126 kJReversible adiabatic means isentropic. Sgen = 0
W = PdV = 500 kPa . (v3-v2)From v=RT/P
v2 = 0.273 m3/kg
v3 = 0.287 m3/kgW = 7 kJ
q - w = ΔH = cp (T3-T2)
q = 32 kJ/kg
Sgen = cpln(T3/T2) - Q/T
This leads me to negative entropy generation. So, I must be making some wrong turns on the way.
The final temperature at the end of step 1 (according to your calculations) is 475 K. The final temperature at the end of step 2 is 500K. So the entropy change of the system is Cp ln(500/475). What is the amount of heat removed from the reservoir is step 2? I get Cp (500-475).
From q - w = ΔH = cp (T3-T2)
I get q = 32 kJ/kg
sgen = Δs - q/T = 0,052 - 32 kJ / 600 K = 0.052 - 0.053 = - 0.01
Edit: Why didn't you involve work in your first law equation? Isn't there some boundary work PdV also. That is why I get q = w + cp(500-475) = 7 + 25 = 32 kJ/kg
I get q = 32 kJ/kg
It's q-w = ΔU, not ΔH. The constant pressure work w is included in ΔH=q=ΔU+w.
Try again. You almost have it. With this change, you will get your desired increase in entropy.
Likes albertov123
Oh, I see. That helped a lot. Thank you so much.
  • · Replies 22 ·
