Entropy of Quark-Gluon Plasma Eq. of State
  • Thread starter Thread starter Spannie
    Entropy Plasma
The discussion centers on the equation of state for quark-gluon plasma, specifically the pressure and internal energy formulas derived from the Stefan-Boltzmann constant. Participants seek to derive an expression for entropy from these equations, with one suggesting the first principle of thermodynamics as a starting point. There is curiosity about the origins of the equations presented and how properties of plasma can be measured to formulate such equations. The mention of the SAHA equation indicates a consideration of alternative approaches to understanding plasma behavior. Overall, the conversation highlights the complexities of deriving thermodynamic properties in quark-gluon plasma.
Spannie
Equation of state for quark-gluon plasma is
p=(127/6) (stephan-boltzmann const/ speed of light) T^4
internal energy is
U=3pV = (127/2)(stephan-boltzmann const/ speed of light)(T^4)V
So how does one get an expression for entropy? or if anyone knows the expression what is it? (I may be able to work backwards)
Cheers
Science news on Phys.org
Hey! Welcome to PF.
Where did you found these expressions?. I didn't know it exists a equation of state for a plasma!. The question is: how can one measure the propierties in a plasma for built up any equations?. I don't understand some people...
Well, to answer your question:
1st principle: dU=TdS-PdV
what happens if you make S=\int{\frac{dU}{T}+\frac{PdV}{T}}?
Spannie, could please give some info on how you acquired these formula's you are using in order to describe this quark-gluon plasma.
Shouldn't you be using the SAHA-equation ? Just a thought...
regards
marlon
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
