Entropy problem involving saltwater uptake into a cell
  • Thread starter Thread starter GoGoGadget
    Cell Entropy
The discussion focuses on a homework problem involving the conversion of saltwater into drinking water, emphasizing the calculation of entropy and energy requirements for the process. Participants express confusion about the role of entropy in the system, particularly regarding the movement of NaCl molecules and the implications for energy consumption. There is a debate about whether to consider proton and neutron counts separately or just atomic masses, as well as the necessity of accounting for the number of molecules in the system. The conversation also touches on the importance of understanding the electrostatic interactions of ions and the impact of temperature changes on the process. Overall, the participants seek clarity on the calculations and principles involved in the entropy problem related to desalination.
GoGoGadget
For public health reasons, you are investigating small systems that turn sea water into drinking water. One portable system takes a volume of saltwater and produces two thirds that volume of freshwater with an increased concentration of salt in the other third of the volume. A typical salinity of seawater is 3.5% and its density is 1025 g/liter. To be practical, this system must run on a small solar cell array. Your first step is to calculate the minimum power necessary to produce enough drinking water for a person in an ordinary environment in a reasonable amount of time. Checking your period chart you find, hydrogen has 1 proton, oxygen has 8 protons and 8 neutrons, sodium has 11 protons and 12 neutrons, and chlorine has 17 protons and 18 neutrons.
F = ma?
I really want to work through this problem with someone on here. Entropy is the one major topic I feel clueless on and this is pretty much the only sample problem I have to practice with before my final exam this week. If someone could work through this problem with me, it'd be so greatly appreciated. I'm unsure on how to begin it...
That link was a little bit too complex for this problem but thank for you it though. I think I figured it out otherwise. I have to think about the molecules being all over the place initially to then thinking about how the NaCl molecules are moved to one third the volume of the water. So it's all about the states of the NaCl molecules. I know that work reduce entropy in a system, for which the equation is W = -T x Sf-Si. And entropy is calculated by: S = k ln (changes in state). So Sinitial would consist of k ln (Vinitial / Vmolecules)^N, showing for the N number of states of NaCl molecules. Then Sfinal would be k ln (Vfinal / Vmolecules)^N, all assuming that the temperature T is constant.
Yes, that's about as far as my vague understanding goes, but I couldn't see why you needed to know the proton and neutron counts separately. You'd only need the atomic masses for that, no? So I wondered whether you had to consider electrostatic interactions of the ions. But then you'd need to take into account that water is only partly ionised.
Wrt temperature, it has to increase, surely?
Yes, I believe I only need proton and neutron counts for determining mass of NaCl. However, do I also need to determine the number of molecules in the system too then? That I was unclear on. Otherwise, I know I'm also provided with the salinity and the density of the saltwater too so I'm not sure what I need to do with that. Otherwise, going off of what I've determined about the entropy, I find I come up with an answer of W = T k ln (3).
W = -T Sf-Si
= T k( ln V/3/Vo)N +k (V/Vo)N
= T k ln (V/3/Vo)N/V/Vo)N
= T k ln(3)
Not sure if there is much after that or not.
It won't be NaCl molecules, it will be Na+ and Cl- ions. From the salinity you can calculate the number of each per unit volume. OTOH, I guess there have to be an equal number of + and - ions in each subsystem, so maybe it's right to treat them as molecules.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
