Equation of Tangent to the Line
  • Thread starter Thread starter johnq2k7
    Line Tangent
johnq2k7
3.) Give the equation of the line tangent to the curve at the given point.
a.) (y)(tan^-1 x) = x*y at (sqrt(3),0)
b.) ln y = x^2 +(2)*e^x at (0, e^2)
Please help me with this problem, I am stuck.
Here is some of my work process:
i have no idea how to solve for y in a.)
but for b.) I took the expontential of both sides
then i got y= e^(x^2) + e^(2*e^x)
do I find the derivate of y to get the slope
but how do i plug in the values of the pt.
do i use the y- yl= m(x-x1) formula to find the tangent to the curve?
please help me with these problems, I'm clueless for part a, and i have a bit of an understanding on how to do part b.)
Put the x value of the point into your formula for the derivative!
Yes!
You may have miscopied part (a). If y is not 0, you can divide through by it and get tan-1(x)= x which means y is not a function of x. I think that there are two points, one positive and the other negative, for which tan-1(x)= x and so the equation is true for all y. Of course, it is true for all x if y= 0 and so its graph is those three lines. If that is really is what (a) says, then since tan^{-1}(\sqrt{3})\ne \sqrt{3}, the curve in a neighbor hood of the point (\sqrt{3},0) is the line y= 0 and so its tangent is the line y= 0.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
