Can the equation of a circle be found using two given points and a tangent line?
  • Thread starter Aladin
  • Tags
    Circle
In summary, the conversation discusses finding the equation of a circle given two points on the circle and the equation of a tangent line. The general equation for a circle is mentioned and it is suggested to use a geometric approach by drawing a picture. It is also mentioned to use the fact that the center of the circle is equidistant from the given points. An example problem is given and a method for solving it is suggested. The conversation also briefly discusses finding the equation of a tangent line and solving for the center of the circle.
Aladin
77
I can't understand the different conditions given and from that equation of the circle is found.For example.
How equation of the circle can be found ? if two points on circle are given and equation of line tangent to the circle is given?
thank you.
Mathematics news on Phys.org
Well, you know the general equation for a circle don't you? If not, try to derive it from what you know (namely, they consist of points which have a fixed distance to -- say -- the origin, and you know the distance of a point to the origin by Pythagoras law, then you can shift the whole thing to the actual center of the circle).
This equation contains two coordinates (e.g. x and y) and three unknowns (namely the coordinates of the centre point and the radius). So if you know two points on the circle, you could plug them in and find two of them.
To get the tangent line, you can rewrite the formula to y = f(x) with f a function that depends on x and the radius, and differentiate it.
That's all I'm going to say now, I think you should think about this and come up with some trials, because I don't know exactly where your problem is.
P.S. Make pictures! Try drawing the points and the given tangent line, or just draw a circle and see what you can derive by looking at the picture.
you could try to use the two points to get an idea of where the center is, since it is equidistant from both. then recall the relation between the center of a circle and the tangent line at a point of the circle. this gives a geometric approach.
Yeah i was thinking of telling him that but what if the points that are giving are not equidistant what if for instance they are next to to each other, or should we assume that must precal questions will give equidistant points.
yeah give an example of a problem you need to solve.
I think you are misunderstanding mathwonk's point. It doesn't make sense to say that two points are "equidistant". You may be thinking of the case where the two points are ends of a single diameter. Mathwonk said that the center of the circle is equidistant from both the given points on the circle. In particular, the center is on the pependicular bisector of a line segment (chord) between any two points on the circle.
Ok The example is that I am taking fro my textbook.
Find an equation of the circle passing through the points A(1,2) and B(1,-2) and touching to the line x+2y+5=0
Well the center obviously lies along the y axis, lucky you. For your convenience write x+2y+5=0 as y = (-x - 5) / 2. The slope of the line perpendicular to this one is 2, so we have y = 2x + b. Now the distance between (0, b) and the intersection of 2x + b with (-x- 5)/ 2 needs to be expressed as a function of b. This done, express the distance between one of the given points and (0, b) as a function of b, equalize the two functions and solve for b.
(Editted by HallsofIvy to change y= -x- 5/2to (-x-5)/2)
1. What is the equation of a circle?
The equation of a circle is (x - h)^2 + (y - k)^2 = r^2, where (h,k) is the center point and r is the radius.
2. How do you find the center and radius of a circle from its equation?
To find the center, you can simply read the values of (h,k) from the equation. The radius can be calculated by taking the square root of r^2.
3. What is the standard form of the equation of a circle?
The standard form of the equation of a circle is x^2 + y^2 = r^2, where (0,0) is the center point and r is the radius.
4. Can the equation of a circle have negative values for the radius?
No, the radius of a circle must be a positive value. If the equation has a negative radius, it is not a circle but rather a different type of conic section.
5. How can the equation of a circle be used in real-world applications?
The equation of a circle can be used to model and solve problems involving circles, such as finding the distance between two points on a circle, determining the circumference and area of a circle, and calculating the trajectory of a circular object.
  • General Math
  • General Math
  • General Math
  • General Math
