Equation vs Identity: Why We Differ Both Sides
  • B
  • Thread starter FAS1998
  • Tags
    Identity
In summary: Differentiating an conditional equation such as ##x = x^2## doesn't completely make sense, because this isn't a function, and functions are the inputs to the differentiation operator. However, if you consider each side as representing its own function; i.e., as ##y_1 = x## and ##y_2 = x^2##, then differentiating each of these equations and setting ##y_1' = y_2'## does result in a solution ##x = 1/2##.Also ## y=x^2## is not an identity, it’s a function of the form y=f(x) over some domain assumed to be reals but could be whatever is meaningful
FAS1998
50
Why are we allowed to differentiate both sides of something like
##y=x^2##
but not something like
##x=x^2##
I believe the answer might be that the first equation is an identity that is true for all values while the second equation is an equation and is only true for some values.
Although I’m not entirely sure if this is correct, and if it is correct, I’m not entirely sure how to distinguish between identities and equations.
Mathematics news on Phys.org
Who said you can’t differentiate on both sides?
Likes FAS1998 and fresh_42
The solution to the second equation is x = 0 or x = 1.
If you differentiate both sides you get
##1=2x##
Which has the solution x = 1/2
##y=x^2##
##x=x^2##
fresh_42 said:
And it says: ##x=x^2 \Longrightarrow \dfrac{d}{dx}\,x=\dfrac{d}{dx}\,x^2 \Longrightarrow 1=2x \Longrightarrow x=\dfrac{1}{2}##
which is the point at which both functions have the same slope ##1##.
The equation ##x = x^2## doesn't represent a function, whereas the first equation above does represent a function.
Likes FAS1998 and jedishrfu
Also ## y=x^2## is not an identity, it’s a function of the form y=f(x) over some domain assumed to be reals but could be whatever is meaningful, like integers or complex numbers...
Likes FAS1998
I don’t quite understand what’s going on there.
I understand that you’re taking the derivative of both sides of the equation, so the solution of the new equation will be the values of x where the derivatives are equal.
But I don’t see how it makes sense to say that
##x=x^2 \Longrightarrow ... \Longrightarrow x=\dfrac{1}{2}##
For the first equation to imply that x = 1/2, wouldn’t x = 1/2 have to be a solution to the first equation?
So would the symbol y in this context represent a different kind of thing than the variable x? Or can y be both a variable and a function of x?
Think of it as two functions x and x^2 and you differentiate to find where they both have the same slope.
Likes FAS1998
For the first equation to imply that ##x = 1/2##, wouldn’t ##x = 1/2## have to be a solution to the first equation?
No, since differentiation is one way. If we want to differentiate ##x## or ##x^2## we assume that they are functions ##x \stackrel{f}{\longmapsto} x\, , \,x\stackrel{g}{\longmapsto} x^2## resp. Now differentiation is - if written accurately - the following operation:
\begin{align*}
x&=x^2 \text{ interpreted as } f(x) = g(x) \qquad \left| \qquad \left. \dfrac{d}{dx}\right|_{x=p} \right.\\
\left. \dfrac{d}{dx}\right|_{x=p} \,x &= \left. \dfrac{d}{dx}\right|_{x=p}\, x^2\\
p &=2p\\
p &=\dfrac{1}{2}
\end{align*}
We evaluate the differential at a certain point ##p##, and that is the slope at this point of ##f(x)\, , \,g(x)## resp. It is a mistake to omit this notation, although it is done all the time. Without the evaluation, we get
1=\dfrac{d}{dx}\,x =\dfrac{d}{dx}\,f=\dfrac{d}{dx}\,g= \dfrac{d}{dx}\,x^2 = 2x
which is an equation of two functions, namely ##x \longmapsto f'(x)## and ##x \longmapsto g'(x)##; or ##p \longmapsto f'(p)## and ##p \longmapsto g'(p)## to emphasise the new role of ##x##. To set them equal is as usual the same as to ask where those functions intersect, which they do at ##p=\dfrac{1}{2}.## But they are two different functions than those we started with.
The confusion is only due to the fact, that those functions nor the evaluation point are mentioned if we only write ##x## or ##x^2##.
Likes FAS1998
I prefer to think of it this way: you cannot differentiate ##x=x^2## because it does not have the structure of a differentiable curve. The solution set consists of two isolated points; thus, we cannot define the derivative on the solution set.
On the other hand, ##y=x^2## has the structure of a curve, so we can ask about the derivative which turns out to be well-defined.
Likes PeroK
##y=x^2##
##x=x^2##
In my view this depends on the mathematical conventions of what we mean by such equations.
If you write: Let ##y = x^2##, then that is actually ambiguous. It could mean:
Let ##y## be a function of ##x## defined by ##y = x^2##.
In which case, you are free to differentiate this function.
Or, it could mean:
Let ##y_0## be a specific number that satisfies ##y_0 = x_0^2##.
In this case, technically, there is no function to differentiate. Although, you could easily turn this into a function by considering ##x_0## as a variable and ##y_0## as a function of this variable.
If, however, you write: Let ##x = x^2##, then in my opinion this can only mean that you have a specific number that satifies ##x_0 = x_0^2##. You could, in fact, rewrite this as:
##x^2 - x = 0##
In this case, there is nothing to differentiate, as all you have is at most two solutions to this quadratic equation.
In summary, I would compare your original question to the following:
##y = x^2 - x##
Is the definition of a quadratic function, which can be differentiated.
##x^2 - x = 0##
Is an equation for the (discrete) roots of a quadratic function and cannot be differentiated (because the equality only holds for at most two values of ##x##).
Note, finally, that an identity is something like:
##\cos^2x + \sin^2 x = 1##
That is an equation that holds for all points. I.e. the graph of the function is the line ##y = 1##. So, that can be differentiated.
Note that, to be very precise here, the symbol ##1## actually stands for the function that is identically ##1##, which is why it can be differentiated.
What is the difference between an equation and an identity?
An equation is a mathematical statement that shows the equality of two expressions, while an identity is a mathematical statement that is always true, regardless of the values of the variables.
How can I tell if a statement is an equation or an identity?
An equation will usually have an equal sign (=) separating the two expressions, while an identity will often have an identity symbol (≡) or will be stated as "for all" or "for every" in the statement.
Why is it important to understand the difference between equations and identities?
Understanding the difference between equations and identities can help in solving mathematical problems correctly and efficiently. It can also help in identifying and proving mathematical concepts and theories.
Can an equation also be an identity?
No, an equation and an identity are two distinct types of mathematical statements. An equation can sometimes be simplified to an identity, but they are not the same.
What are some examples of equations and identities?
An example of an equation is 2x + 3 = 7, while an example of an identity is (x+y)^2 = x^2 + 2xy + y^2.
  • General Math
  • General Math
  • General Math
