Equations Involving Vectorssss
  • Thread starter Thread starter ziddy83
To find a vector equation and parametric equations for the line through the point (1,0,6) and perpendicular to the plane defined by x + 3y + z = 5, one must identify the normal vector of the plane, which is derived from its coefficients (1, 3, 1). The line's direction vector will be the same as the normal vector, ensuring it is perpendicular to the plane. Using the point and the direction vector, the vector equation of the line can be constructed. The parametric equations can then be derived directly from this vector equation. Understanding the relationship between the plane's coefficients and the line's direction is crucial for solving the problem.
ziddy83
Equations Involving Vectorssss...
hey guys...stuck on a homework problem here... very simple but...im not sure how to start...
Here is the question: Find a vector equation and parametric equations for:
The line through the point (1,0,6) and perpendicular to the plane x + 3y +z =5
can i just..use that equation to find parametric equations and then find vector equations from that :confused: ? Thanks for any help...
do you remember what the meaning of the co-efficients of the plane are? I suggest you look that up, and then remember that all you need to make the equation of a line is a directional vector and a point. That's the absolute simplest way to do it. The parametric equations come straight from that.
try here:
http://www.usd.edu/~jflores/MultiCalc02/WebBook/Chapter_13/Graphics/Chapter13_5/DemoHtml13_5/13.5%20LinesAndPlanes.htm
the first equation indicates the vector equation of a line thru point r0 (which is given to be <1,0,6> here) and parallel to vector v. if the line is normal to the plane given above, then this line is parallel to the plane's normal vector (which will be used for v). scroll down the page of the above URL to determine a vector v normal to the plane (which can be determined from the coefficients of the plane equation given above). the parametric line equation can easily be found from the vector equation.
What do you need for the parametric equation of a line? , You need one point on it and the direction cosines of the line.Now because the line is prependicular to the above given plane.So the direction ratios of the line will be same as direction ratios of a normal vector to the plane.From the equation of the plane , you can make out that the vector prependicular to the plane given is a vector: i + 3j + k , So the direction ratios of the required line are 1,3,1 and it passes through point 1,0,6 . Find the direction cosines from the direction ratios and form the parametric equation of the line.
BJ
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
