Understanding Equilibrium Stability in Classical Mechanics: Virtual Work Lecture
In classical mechanics, the stability of equilibrium can be assessed using the second derivative of potential energy, U. If the second derivative, ∂²U/∂x², is positive, the potential is at a minimum, indicating stable equilibrium. Conversely, if it is negative, the potential is at a maximum, signifying unstable equilibrium. Objects in a potential field tend to move towards lower potential, aligning with the direction of force. Understanding this relationship is crucial for analyzing equilibrium stability in mechanical systems.
gulsen
In classical mechanics - virtual work lecture, for determining equilibrium stability we were told that second derivate of potential can be used. How?
I've made a quick google search, but couldn't find anything remarkable.
If \frac{\partial^2U}{\partial x^2} is postive then U is at a minimum (basic calculus - second derivative test). If instead it is negative then U is at a maximum. A point of equilibrium is stable if U is minimum and unstable if U is maximum.
I guess this because objects in a potential field tend move through where their potentials get lower?
Absolutely! After all, which way does the force point?
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
