How Do You Calculate Error Uncertainty for ln(x)?
  • Thread starter Thread starter johnnnnyyy
    Uncertainty
To calculate the error uncertainty for ln(x), the derivative d/dx ln(x) = 1/x is used, leading to the approximation that the error uncertainty for ln(10) with an uncertainty of ±1 in x is about (1/10)*2.3. For small changes in x, a Taylor series expansion can improve accuracy, with the first term providing a close approximation. The correct value of ln(10) lies between ln(9) and ln(11), but the fractional error distribution varies slightly. For small fractional changes, the ratio of the fractional error in ln(x) to that in x is approximately 0.4343, though this ratio diverges for larger changes in x. Understanding these relationships is crucial for accurately calculating error uncertainties in logarithmic functions.
johnnnnyyy
What would be the error uncertainty when you take ln of a number. For example ln(10) and the error uncertainty for 10 is ± 1
Is the error uncertainty just (1/10)*2.3? (2.3 is the answer to ln(10))
d/dx ln x = 1/x
what is d(ln x) in terms of dx?
That's for small changes in x.
For larger changes in x, say x → x+a, you can Taylor-series-expand ln (x + a). The first term is of course the above = ln x + a/x , then the higher terms give you better accuracy.
In your case, x = 10 and a = 1, the small-change approximation above gets you to within 0.9980 of the correct answer. Adding just 1 extra term in the series gets you to within 0.9999 of the exact answer. Etc.
So the correct answer lies between ln(9) and ln(11)?
Those are the extremes, yes, but the fractional error distributions differ slightly between x and ln(x).
For small δx/x the fractional change in ln(x) is δ[ln(x)]/ln(x)] ~ [1/ln(x)] δx/x = 0.4343.
E.g. for δx = +1 and x = 10,
fractional change in ln(x) = [ln(11) - ln(10)]/ln(10) = 0.04139 for fractional change in x = 1/10 = 0.1000. So δln(x)/ ln(x) = 0.4139 δx/x.
but if δx = 0.1, fract. change in ln(x) is [ln(10.1) - ln(10)]/ln(10) = 0.004321 for a fractional change in x of 0.1/10 = 0.0100. So δln(x)/ln(x) = 0.4321 δx/x, pretty close to 0.4343.
Which as I said is not a big difference. So with little error, you can say that the fractional error in ln(x) is proportional to the fractional error in x, that ratio being 0.4343, if |δx/x| < 0.1.
But say δx = 5, then
fract. change in ln(x) = [ln(15) - ln(10)]/ln(10) = 0.1761 for δx/x = 0.5, so that ratio is 0.1761/0.5 = 0.3522 which is quite a ways from 0.4343.
