Estimating image distance in lens and mirror
  • Thread starter Thread starter ShineyPenny
    Image Lens Mirror
Estimating the location of an image in a lens or mirror can be confusing, particularly when applying the correct formulas. The discussion highlights the importance of using the thin lens equation, which is often not included in textbooks. A participant initially misapplied values and struggled with the focal length's sign, leading to incorrect calculations. After clarification, it was confirmed that the textbook had an error, and the correct calculation yielded an image distance of approximately 5.33 cm. Understanding the proper application of the thin lens equation is crucial for accurate image distance estimation.
ShineyPenny
I'm having difficulty understanding how to estimate the location of an image in a lens/mirror.
I tried understanding it by going off the books question/answer section:
"A spherical concave lens has a focal length of 16 cm, and an object is placed 8 cm from the lens." It says the answer is 6.0 cm.
What formula is being used, I cannot figure out how they got 6 cm? All I see in the book for formulas is f=R/2 and R=2f.
I'm confused :(
For a lens, it's usually called the "thin lens equation", sometimes with "Gaussian" in front of it. Your textbook surely has it. Try the index at the end of the book. :smile:
The two formulas you named, give the focal length of a mirror with radius R. There's a similar (but a bit more complicated) formula for the focal length of a lens, which is usually called the "lensmaker's equation." But you don't need that for this problem.
Oh, and either you left out a minus sign, or the book has a typographical error, or it's being deliberately sneaky. A concave lens has a negative focal length, not positive.
OK, I believe I have it after running a search for it...it's actually not in the book :(Is the equation:
(1/Object Distance)+(1/Focal Length) = (1/image location)
(1/45) + (1/36) = .05; then (1/.05) = 5.999
This is it? I'm just making sure :)
It's actually usually written as
\frac{1}{o} + \frac {1}{i} = \frac {1}{f}
where o, i and f are object distance, image distance and focal length. Some books use s and s', or p and q, instead of o and i.
Why are you using 45 and 36 for object distance and focal length, when your original problem had 8 and 16? (actually -16 because it has to be negative as I said before)
I have no idea where 45 and 16 came from, sorry it was a long night :blushing:
I input (1/8o) + (1/-16i) = .0625f, then go (1/.0625f) and come out with 16.
Either I'm missing something big, or I haven't drank enough coffee this morning. I even plugged the numbers into this website (http://www.photonics.byu.edu/Thin_Lens_Calc.phtml) and it's not coming up with 6 cm for the image location.
Sorry, I'm not a math person but I'm trying to grasp this :confused:
OK
I have figured it out, the book is wrong and it was verified by the professor :)
I inputted: (1/16f) + (1/8o) = .1875, then (1/.1875)= 5.33.They did not use a negative sign.Thank you! =)
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
