Euclidean Algorithm terminates in at most 7x the digits of b
Terrell
please see the image
I'm not sure if this is relevant:
##r_2 \leq \frac{1}{2}r_1## ... ##r_n \leq (\frac{1}{2})^nr_1##
i have shown that ##r_{i+2} < r_i## by showing the ##r_{i+2} - r_i## is negative, but how do I show that the number of steps is at most ##2 \log_{2}b##
That is not what the question requires though. It requires to show that ##r_{i+2} < \frac12 r_i##. Have you shown that?
Once you have shown ##r_{i+2} < \frac12 r_i## you can work out how many steps it takes to reduce the remainder to 1 or less, as the algorithm terminates when the remainder reaches 1 or 0. Use the fact that the remainder halves every two steps and that initially it is no greater than ##b##..
Sorry I meant ##2r_{i+2} < r_i##
andrewkirk said:
Use the fact that the remainder halves every two steps and that initially it is no greater than bbb..
I am not sure if I am doing this completely right or wrong.
proof of ##r_{i+2} < \frac{1}{2}r_i:##
Let ##a - bq_1 = r_1## s.t. ##b=r_0##
##(case 1):##
If ##b=r_0< \frac{1}{2}a## then ##q_1 \geq 2## so that ##r_1 < r_0##.
Furthermore, in ##r_0 - r_1q_2 = r_2##, since ##r_1 \leq \frac{1}{2}r_0## then it must be that ##q_2 \geq 2## so that ##r_2 < r_1##.
Therefore, ##r_2 < r_1 < \frac{1}{2}r_0## or ##r_{i+2}<r_{i+1}< \frac{1}{2}r_i## or simply ##r_{i+2}<\frac{1}{2}r_i##.
##(case 2):##
If ##b=r_0> \frac{1}{2}a## then ## a- r_0q_1 = r_1## such that ##r_1 < \frac{1}{2}a## and ##r_1 < r_0## and ##q_1=1##
##(subcase 2.1):## If ##r_1 > \frac{1}{2}r_0## then definitely, ##r_2 < \frac{1}{2}r_0## or ##r_{i+2}<\frac{1}{2}r_i##
##(subcase 2.2)## If ##r_1 < \frac{1}{2}r_0## then ##q_2 \geq 2## so that ##r_2 < r_1##.
Therefore, ##r_2<r_1< \frac{1}{2}r_0## or ##r_{i+2}<r_{i+1}< \frac{1}{2}r_i##
From here, I am struggling to apply logarithms to show the final step. Can you give me hints?
You may get more response if you show the image rather than just giving the link. I'll do that much for you.
The image for the link you posted:
Notice that if ##\ b\ ,\ ## which is also ##\ r_0\ ,\ ## has k decimal digits, then b < 10k .
Likes Terrell
The hint is the last paragraph of post #2.
Another hint:
What upper bound on rn will ensure that the algorithm terminates in at most n steps.
I figured that the inequality ##b(\frac{1}{2})^\frac{n}{2} < 1## then taking the log of both sides should be enough...?
##r_n \leq 1##
SammyS said:
Notice that if b , b , \ b\ ,\ which is also r0 , r0 , \ r_0\ ,\ has k decimal digits, then b < 10k .
yes i do notice, but can this be helpful to particularly show that it takes less than 7 times the no. of digits of b?
It's probably enough for ##\displaystyle b(\frac{1}{2})^\frac{n}{2} < 2\ .\ ## Right.
Combine this with b < 10k .
So if ##\displaystyle 10^k (\frac{1}{2})^\frac{n}{2} < 2\ ,\ ## then ...
Likes Terrell
##2\log_2(b)<n## then by letting ##b = 10^k## we get ##2k\log_2(10)<n##. Also ##2\log_2(b)=6.6438...## therefore it can be at most 7 times the number of digits of ##b##. Thank you Sammy!
