Euclidian space en U is a linear subspace
damabo
show that (U\bot)\bot=U, if (ℝ,V,+,[,.,]) an Euclidian space en U is a linear subspace of V.
suppose \beta={u_1,...,u_k} is an orthonormal basis of U.
pick u in U. Then u=x_1u_1+...+x_ku_k for certain x_1,...,x_k in ℝ.
pick u'_1,...,u'_k as orthonormal basisvectors of U\bot, where u'_i\botu_i for all i. and consequently take basisvectors u''_1,...,u''_k for U\bot\bot that are orthogonal to the previous. then it follows that u''=x_1u''_1+...+x_ku''_k = x_1u_1+...+x_ku_k = u.
this means that U\subsetU\bot\bot and also that both have the same dimensions, and consequently that they are the same subspaces (since span(u_1,...,u_k)=span(u''_1,...,u''_k)=ℝ^k).
I am confused as to what you mean by U⊥. I would expect that to mean "the orthogonal complement of U" but that requires that U be a subset of some larger space. If you mean "orthogonal complement, what larger space are you assuming?
see the problem statement: U\bot is indeed the orthogonal complement and V is the Euclidian space of which U is a subspace. U\bot\bot is thus the orthogonal complement of the orthogonla complement.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
