- 1,442
- 191
I am working on my thesis, one topic therein is Euler's series transformation, would you kindly look over my derivation of it?
Workin with the function f(x) defined by the following power series (convergent for at least -1<x\leq +1,)
consider the change of variables given by
where q is a constant, and for which
so that we have (applying the change of variables to f(x),)
re-index to start with k=0 to get
where the order of summation was reversed according to the rule
Also note, that (according to the transformation variables given above,) the value y=\frac{1}{q+1} corresponds to x=1; thus, considering f(1) gives
which, upon setting q=1, gives Euler's Series transfromation as a special case, namely
which is useful for series convergence acceleration (sometimes) and for the analytic continuation for functions defined by series. Any thoughts?
f(x)=\sum_{k=1}^{\infty}(-1)^{k-1}a_{k}x^{k}
x=\frac{y}{1-qy},
x^k=\left( \frac{y}{1-qy}\right) ^k = y^k \left( \frac{1}{1-qy}\right) ^k = \frac{y^k}{(k-1)!q^{k-1}}\frac{d^{k-1}}{dy^{k-1}} \left( \frac{1}{1-qy}\right) = \frac{y^k}{(k-1)!q^{k-1}}\frac{d^{k-1}}{dy^{k-1}} \left( \sum_{n=0}^{\infty}q^ny^n \right)
= \frac{y^k}{(k-1)!q^{k-1}} \left( \sum_{n=k-1}^{\infty}\frac{n!}{(k-n+1)!}q^ny^{n-k+1} \right) = \frac{1}{q^{k-1}} \sum_{n=k-1}^{\infty} \left(\begin{array}{c}n\\k-1\end{array}\right) q^ny^{n+1}
f\left( \frac{y}{1-qy}\right) = \sum_{k=1}^{\infty}(-1)^{k-1}a_{k}\left( \frac{y}{1-qy}\right) ^{k} = \sum_{k=1}^{\infty}(-1)^{k-1}a_{k} \frac{1}{q^{k-1}} \sum_{n=k-1}^{\infty} \left(\begin{array}{c}n\\k-1\end{array}\right) q^ny^{n+1}
f\left( \frac{y}{1-qy}\right) = \sum_{k=0}^{\infty} \sum_{n=k}^{\infty} (-1)^{k}\frac{a_{k+1}}{q^{k}} \left(\begin{array}{c}n\\k\end{array}\right) q^ny^{n+1} = \sum_{n=0}^{\infty} \sum_{k=0}^{n} (-1)^{k}\frac{a_{k+1}}{q^{k}} \left(\begin{array}{c}n\\k\end{array}\right) q^ny^{n+1} = \sum_{n=0}^{\infty} q^ny^{n+1} \sum_{k=0}^{n} (-1)^{k} \left(\begin{array}{c}n\\k\end{array}\right) \frac{a_{k+1}}{q^{k}}
\sum_{k=0}^{\infty} \sum_{n=k}^{\infty} b_{k,n}= \sum_{n=0}^{\infty} \sum_{k=0}^{n}b_{k,n}
f(1) = \sum_{k=1}^{\infty}(-1)^{k-1}a_{k} = \frac{1}{q+1}\sum_{n=0}^{\infty} \left( \frac{q}{q+1}\right) ^{n} \sum_{k=0}^{n} (-1)^{k} \left(\begin{array}{c}n\\k\end{array}\right) \frac{a_{k+1}}{q^{k}}
\boxed{ \sum_{k=1}^{\infty}(-1)^{k-1}a_{k} = \sum_{n=0}^{\infty} \frac{1}{2^{n+1}}\sum_{k=0}^{n} (-1)^{k} \left(\begin{array}{c}n\\k\end{array}\right) a_{k+1} }
