Evaluate an Integral Using a Specific Hint
14 replies · 3K views · last reply
LilTaru
[tex]\int[/tex] dx/(x4 + 16)
Hint: With a>0, x4 + a2 = (x2 + [tex]\sqrt{}2a[/tex]x + a)(x2 - [tex]\sqrt{}2a[/tex]x + a)
I've plugged this into the equation, which leaves me with:
[tex]\int[/tex] dx/[(x2 + [tex]\sqrt{}2a[/tex]x + a)(x2 - [tex]\sqrt{}2a[/tex]x + a)]
But now I am sooooo confused! Where do I go from here? This hint does not seem so helpful... Please help!
Rewrite the 1/hint
as
[tex]\frac{1}{{(x^2+ \sqrt{2a}x + a}{( x^2 - \sqrt(2a) + a)}} = \frac{Ax+B}{(x^2+ \sqrt{2a}x + a} + \frac{Cx+D}{ x^2 - \sqrt(2a) + a}[/tex]
then bring the right side to the same denominator and equate the numerators. Then choose values of x to get the constants A,B,C,D.
Yeah. This was my first approach but if you plug in the value of a = 4, it seems the two factors of the hints never equal 0... Maybe this is just me.
If you can't pick values of x that decide certain values, there is another option, although it's not as fun: find the powers of x on each side and equate them to get a system of equations that you can solve.
They don't need to equal to zero necessarily, the equation would be true for all values of x.
Okay... I tried to solve for the constants but I am stuck... I get this equation:
1 = (Ax + B)(x2 - 2*sqrt(2)*x + 4) + (Cx + D)(x2 + 2*sqrt(2)*x + 4)
I can't see how to solve this either by finding an x where the factors are zero or by solving a system of equations... How can I turn this into a system of equations?
Right, well you can multiply it out and equate coefficients OR you can put in values for x and get equations. For example, you can choose x=2,3,etc. and you will get equations to solve.
But I thought when you put in values of x it should make one of the factors be 0 so that you can solve for the other one?
I did not mean it like that.
You have 4 unknowns and the equation is true for all values of x.
So you can put in 4 different values for x and get 4 equations.
I've tried solving the system of equations but cannot seem to get it not matter how hard I try... can someone please help me solve the system? After that I know how to do the integral.
Main equation: 1 = (Ax + B)(x2 - 2[tex]\sqrt{}2[/tex]*x + 4) + (Cx + D)(x2 + 2[tex]\sqrt{}2[/tex]*x + 4)
Set x = 0: 1/4 = B + D
Set x = sqrt(8): 1 = 8*sqrt(2)A + 8B + 40*sqrt(2)C + 20D
Set x = sqrt(2): 1 = -2*sqrt(2)A - 2B + 28*sqrt(2)C + 14D
Set x = 3*sqrt(2): 1 = 30*sqrt(2) + 10B + 102*sqrt(2) + 34D
Which by looking at the answers seems impossible plus possibly horribly wrong. Can someone tell me what they get please?!
After looking on the internet for a sample problem like this... I have found I am retarded... Figured out the problem: equated the coefficients wrong! Thank you all for your help! :P
