Evaluate integral using substitution
Col Musstard
evaluate using substitution
Integral [cos^-1 x]/sqrt[1-x^2] dx
I am just starting with integration and I am getting frustrated with this problem. If someone could show me how to setup and start this problem so I could attempt to continue by reading instructions from my textbook it would be greatly appreciated
Hint: What's the derivative of cos^{-1} x?
that is -1/sqrt[1-x^2] isn't it
Yup. Note that it's the other part of the integrand, so that means you should use a substitution.
so u=cos^-1x. therefore du=-1/sqrt[1-x^2] dx
is this correct so far?
I got -[[cos^-1x]^2]/2 +c hope its right, thanks for the help
Yes, that's the correct answer. You can always differentiate what you got and see if you get back the integrand.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
