Evaluate the integral with C be the boundary of the domain
The problem involves evaluating a line integral over a boundary defined by the curves y = x^2 and y = x, with a focus on applying Green's Theorem. The original poster and participants are exploring the setup and limits for the integral.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the applicability of Green's Theorem and the need to express the integral in terms of a double integral. There are questions about the limits of integration and the necessity of including "dy" in the formulation.
The discussion is ongoing, with participants attempting to clarify the limits of integration and the correct setup for the double integral. Some guidance has been offered regarding the interpretation of the region defined by the curves, but no consensus has been reached on the final approach.
Participants are grappling with the implications of the curves' intersection points and the correct limits for the double integral, noting that the region is not a simple square.
tavo0116
Let C be the boundary of the domain enclosed between y = x^2 and y = x. Assuming C is oriented counterclockwise. Evaluate the integral
∫c (6xy+e^(-x^2))dx
I was thinking of using Green's Theorem. Would be the approach be correct?
d/dy (6xy+e^(-x^2))dx = 6x, and integrate that I got 3x^2
What would be the limit? Would the problem be double integral since there is no "dy".
Would the limit be from 0 to 1 since y = x^2 is a parabola, and y = x is a diagonal line through the origin?
What about the dy? Would it need to be added? How?
∫c (6xy+e^(-x^2))dx
One side of Green's theorem is a double integral. If you were asked to find the area between those two curves, could you set up the double integral with limits for that? That is what you want, with the integrand being 6x.
But there is no "dy" , I still don't understand that.
Would the limit of x is from 0 to 1, and limit of y is from y to √y ?
You didn't answer my question.
Your original problem is$$
\int_C (6xy + e^{-x^2})dx + 0dy$$Does that help? Write down the other side of Green's theorem.
d/dx (0) - d/dy (6xy+e^(-x^2))
∫0 to 1 ∫0 to 1 (-6x)
I've tried to find the limits of x by setting up x = x^2, which then gives me x = 0, and x = 1, and for y, I use √y=y, which gives me y = 0, and y = 1
Would those be the right limits for the double integral?
No. 0 to 1 on both integrals describes a square. Your region isn't a square. Look in your calculus book for the formula for the area between two curves.
