Evaluating a limit to 2 decimal places
  • Thread starter Thread starter meeklobraca
    Limit
meeklobraca
If f(x) = sin x, evaluate
lim f(2+h) - f(2) / h
h->0
Evaluate to 2 decimal places
I think that since f(2) then the answer is sin 2 which is .91
What do you guys think?
h->0
If it said lim sin(h) as h->2, then the answer would be sin 2 since sin(x) is continuous.
However, the limit expression is not sin(x), it is f(2+h) - f(2) / h as h->0. Does this limit look familiar? What does it define?
But I suspect that this problem was intended to lead to the derivative of sin x and so that method would be inappropriate. What if you just try small values of h in
\frac{sin(2+h)- sin(2)}{h} and see how small h has to be to so that you get the same answer to 2 decimal places?
Halls, I actually did the equation like you have it there, and then using the sum rule for sine, sinacos b - cos asinb I got a final answer of cos 2 which equalled -0.42. I haven't plugged in any values to check my work, i just fiddled with the equation.
All the problem asked is that you plug in values!
What I meant was, since sin(2)= 0.9093,
Taking h= 0.1, (f(2+h)- f(2))/h= (sin(2.1)- sin(2))/.1= -.4609.
Taking h= 0.01, (f(2+h)- f(2))/h= (sin(2.01)- sin(2))/.01= -.4206
Taking h= 0.001, (f(2+h)- f(2))/h= (sin(2.001)- sin(2))/.001= -.4166
Taking h= 0.0001, (f(2+h)- f(2))/h= (sin(2.0001)- sin(2))/.0001= -.4162
I did it the way I did it because there was an example in my manual that led me to do it that way. I did it your way too and both ways led me to the same answer.
Thanks for your help!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
