Evaluating an integral when theta>0
  • Thread starter Thread starter nick.martinez
    Integral
The integral ∫ e^(-y/θ) dy from 0 to ∞ is evaluated using the limit approach, where θ is a positive constant. The correct anti-derivative is -θ*e^(-y/θ), and the evaluation involves taking the limit as y approaches infinity and zero. As y approaches infinity, e^(-y/θ) approaches zero, leading to a finite result. The discussion emphasizes the importance of recognizing θ as a constant and correctly applying the limits of integration. Understanding these steps is crucial for accurately evaluating the integral.
nick.martinez
∫ e^(-y/θ) dy
The directions say evaluate when theta>0.
I have been integrating by using u of substitution and been getting -θ*e^(-y/θ) and evaluating from 0 to ∞ and getting the answer as undefined. I need help with evaluating the integral. Please help. Thanks.
nick.martinez said:
∫ e^(-y/θ) dy
the directions say evaluate when theta>0
i have been integrating by using u of substitution and been getting -θ*e^(-y/θ)
and evaluating from 0 to ∞ and getting the answer as undefined. i need help with evaluating the intrgal. please help. thanks
Are you familiar with the anti derivative of ##e^{- \frac{x}{a}}##?
nick.martinez said:
∫ e^(-y/θ) dy
and evaluating from 0 to ∞ and getting the answer as undefined. i need help with evaluating the integral. please help. thanks
Your result should not be "undefined".
You have the correct anti-derivative.
Write \displaystyle \ \int_0^{\infty}e^{-y/\theta}\,dy\ as \displaystyle \ \lim_{a\to\infty} \int_0^{a}e^{-y/\theta}\,dy\ .
Now use your anti-derivatve with the limits of integration, then take the limit.
No, I'm not. How is it used in this situation?
You want to evaluate the integral \int e^{-y/\theta}, dy. What happens when you make the substituion u = {\frac{-y}{\theta}} ? What is du ?
Can you generalize to \int f(cx)\, dx when you know what \int f(x)\, dx is? This is a useful result to know when evaluating integrals so you don't always have to make these substitutions.
How would i take the anti derivative if says to evaluate for all theta> 0 not quite sure how to do this.
What happens to -θ*e^(-b/θ) as b goes to ∞? to 0? Remember that θ is just a constant.
is theta a constant even though in the directions it says evaluate from theta>0.
No. It says evaluate when θ > 0 .
If θ ≤ 0, then \displaystyle \ \int_0^{\infty}e^{-y/\theta}\,dy\ does not converge.
(Did you not understand my previous post?)
For some reason I'm not understanding what you are saying, SammyS. HS scientist just said it was a constant, and I was disagreeing. Is there any way you could give me the answer and answer how you got it?
Thanks
also since it says evaluate when theta > 0 this means that all values to infinity so doesn't this mean when evaluating ill get infinity/infinity is the exponent.
nick.martinez said:
for some reason I am not understand what you are saying sammys. HS scientist just said it was a constant and I was diagreeing. is there any way you could give me the answer and answer how you got it?
Thanks
This just means θ is a constant, and it's positive.
In your Original Post, you said that using u substitution, you got -θ*e^(-y/θ) .
That's the correct result for the indefinite integral, \displaystyle \ \int e^{-y/\theta}\,dy\ . Another way to say that is: The anti-derivative of \displaystyle \ e^{-y/\theta}\ is -θ*e^(-y/θ) .
Do you know how evaluate a definite integral (with limits of integration), if you know the indefinite integral (without limits of integration)?
yes i know how to evaluate the definite but when the values of theta are : theta>0 how do you evaluate this when the limits of integration are also from 0 to infinity?
Again: θ is simply some constant -- it happens to be positive. The variable of integration is "y" . It's y that goes from 0 to ∞ as specified by the limits of integration.
Let's try to do this step by step:
\displaystyle\lim_{y\rightarrow \infty} {-\theta e^{-y/\theta}} = <br /> <br /> -\theta \displaystyle\lim_{y\rightarrow \infty} {e^{-y/\theta}} =
-\theta (\displaystyle\lim_{y\rightarrow \infty} {e^{-y}})^{1/\theta}.
Since \theta is greater than zero, what can you say about this limit?
Similarly, what about -\theta (\displaystyle\lim_{y\rightarrow 0} {e^{-y}})^{1/\theta}?
Yes, thank you. I should be more careful when writing out solutions.
You may still be able to go back and Edit that post.
Added in Edit:
Now that you've made the change, I'll delete my post regarding the typo.
(I think PF gives you something like a 700 minute window for Editing.)
Wow, I did not realize that there is such a long allowed time to edit posts. Thanks!
  • · Replies 18 ·
