Even another 2-slit experiment setup
  • Context: Graduate
  • Thread starter Thread starter Nacho
    even Experiment
This discussion centers on a proposed experimental setup involving entangled photons emitted from a central source, L, with beam splitters on both sides. The left photon encounters a solid screen while the right photon passes through a double slit before reaching another solid screen. The key question is whether varying the distance L2 (the left side screen) relative to R2 (the right side screen) affects the interference pattern observed on the right side. The conclusion drawn is that if the 'which path' information from the left photon can be determined, the interference pattern on the right side will disappear; however, if this information remains ambiguous, interference may still occur.
  • Understanding of quantum entanglement and photon behavior
  • Familiarity with beam splitter functionality
  • Knowledge of interference patterns in double slit experiments
  • Concept of 'which path' information in quantum mechanics
  • Research the principles of quantum entanglement and its implications in experiments
  • Study the mechanics of beam splitters and their role in photon experiments
  • Explore the concept of interference patterns in quantum mechanics
  • Investigate the implications of 'which path' information on quantum interference
Physicists, quantum mechanics enthusiasts, and researchers interested in experimental setups involving entangled photons and interference phenomena.
Nacho
I'm interested in knowing what would happen in this setup, if anybody knows. I don't have a way to make a diagram, but the setup is pretty easy.
Say that in a central location, call it L, you have a source of entangled photons that emit one to the left side and the other to the right side 180 degrees away. I don't know if you need beam splitters to make it work, but we can put some in anyway just in case .. so ..
The left hand photon travels length L1 and encounters its beam splitter and the right hand photon travels length R1 and enounters its beam splitter. L1 = R1. In both segments the photons have a choice of traveling straight on, or deflecting 90 degrees (downward on your page if you are making a diagram). Consider only the photons that get deflected downward.
On the R side at distance R2 from its beam splitter is a screen with 2 slits, and beyond that is a solid screen. On the L side at distance L2 from its beam splitter is only a solid screen. L2 = R2, but the experiment is built so that distance L2 can be varied to a distance shorter or longer than R2.
I'm assuming the experiment can be set up so that an interference pattern will appear on the solid screen on the R side.
My question is this: As you adjust the solid screen on the L side, distance L2, longer than R2 to shorter than R2, will that have any effect on whether an interference pattern developes on the R side?
I would think that as long as L2 > R2 a pattern can be observed, but when L2 < R2 the interference pattern would disappear.
This is essentially what was discussed in the 'EPR and FTL' thread. If is possible, even in principle, to determine which slit a photon went through, you don't get interference. To determine which slit each photon went through, you need the 'which path' information, since this is not accessible after a photon goes through a regular double slit setup, you get interference. In your setup, the which path information is carried by the left hand photons, and it is possible to extract this information without measuring the right hand one directly, so you don't get interference.
However... I think if it is somehow impossible to tell which left hand photon corresponds to which right hand photon, it is impossible to tell which slit each right hand photon went through, so you should get interference. So basically I don't know what would happen! :( I'll leave it to someone more knowledgeable to answer. But I would say read the EPR and FTL thread, it might answer some of your questions.
Hmmm .. I take back what I thought it would do, as if it did you could fashion a sort of Morse Code FTL communication. I don't know what it would do.
  • · Replies 20 ·
  • · Replies 40 ·
  • · Replies 81 ·
  • · Replies 32 ·
  • · Replies 17 ·
