Example of a continuous function
joxer06
Hi, just a home work question I am having problems with. it has to be solved graphically.
(1) Give an example of a continuous function f : [a,b] -> R that has no local maximum or local minimum at an endpoint
There's not much one can do without basically giving you an answer. But you might try drawing some graphs that satisfy the requirements, then see if you can think of a function that's similar looking.
So neither endpoint is a local min or max, which means?
Oh, it has to be solved graphically. I guess drawing graphs wouldn't be so useful there. Sorry about that.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
