Example of moment of inertia constant K, greater than one?
The moment of inertia constant, k, typically ranges from less than one to one, representing the average distance of mass from the axis of rotation. An example of k being greater than one could occur with a thin square pipe rotating around its long axis, measured from face to face. When all mass is concentrated at a distance r from the axis, k equals one, as seen in a bicycle wheel. The discussion raises questions about the characteristics of objects with k equal to one and the implications of k being greater than one. Understanding these values is crucial for analyzing rotational dynamics.
liometopum
Regarding the moment of inertia constant, k, as in I = kmr^2, k is often a fraction less than one, and sometimes is equal to one. http://en.wikipedia.org/wiki/List_of_moments_of_inertia
Is there an example of k being greater than one?
The "k" is, in some sense, a measure of the average distance of the mass of an object from its axis of rotation. If all of the mass of the object is within radius r from the axis of rotation then the figure for k is guaranteed to be less than or equal to one.
The value of 1 is obtained when all of the mass is exactly at distance r from the axis of rotation. This would apply for something like a bicycle wheel where the mass is concentrated at the rim.
If you considered a thin square pipe rotating its long axis and if you measured its radius r from face to face (rather than from corner to corner) then I suppose that could give you a figure for k that is greater than one.
What does an object with k = 1 look like? What would it mean for k > 1?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
