Excess pressure inside a Liquid drop
The discussion focuses on the role of surface tension in maintaining equilibrium within a liquid drop, particularly a hemispherical shape. It highlights the balance of forces: external atmospheric pressure, internal pressure, and the force due to surface tension. The equation P = P0 + 2σ/r illustrates how surface tension contributes to the pressure inside the drop. Questions arise about the necessity of surface tension for equilibrium and the implications if surface tension were zero, suggesting that fluid behavior would change significantly. Overall, surface tension is crucial for preventing the drop from bursting and maintaining its shape.
Vivek98phyboy
While studying about the effects of surface tension i came across the excess pressure inside a liquid drop.
Here they considered a hemisphere ABCDE from the drop and listed out the conditions for it to be in equilibrium.
The forces acting on them are taken as
F1= 2πRS
F2= P1×(Projection of hemispherical surface on ABCD)
=>F2=P1×πR²
F3=P2×πR²
For equilibrium we take
F1+F2=F3
But what role does the surface tension (T) has in maintaining the equilibrium for a hemisphere.
My doubts are:
1. Isn't the pressure due to Atmosphere and the pressure inside the hemispherical drop enough to balance each other. Why do we need a surface tension here?
2. When i referred some other sources, it said that the surface tension holds the drop from bursting. If it is so, the force due to T we calculates here acts only along the base periphery of the hemisphere. What effect would it have on the curved surface?
Hope this won't come under Homework help
The surface tension of the bubble is due to the attraction of molecules with their neighbors thus pulling them closer and causing the surface area to shrink. This naturally will increase the pressure inside until an equilibrium situation is produced.
In the analysis three forces are identified. That due to the outside pressure pushing on the surface (P0πr2) that due to the surface tension acting in the surface on the circumference (2π rσ) which act together and that due to the inside pressure (P πr2) countering the other two to produce the equilibrium situation. where r is the radius and σ is the surface tension
The pressure in the bubble is constant throughout . The splitting of the bubble into two hemispheres simplifies the analysis.
thus
P πr2 = P0πr2 + 2π rσ
or P = P0+ 2σ/r
thus
or P = P0+ 2σ/r
What if the surface tension is zero?
How would the hemispherical part of the drop behave?
See comment #2 by @.Scott in the thread:
Zero surface tension: "It would signify that the molecules within the fluid have the same attraction to each other as to the atmosphere at the surface."
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
