I Expanding linear independent vectors
member 428835
Hi PF!
The other day in class my professor mentioned something about expanding linear independent vectors, but he did not elaborate. From what I understand, if ##x_1,...,x_k## are linearly independent vectors in ##V##, where ##dimV=n>k##, how would you extend ##x_1,...x_k## to a basis ##\{ x_1,...,x_n \}##. Let's say ##\{ y_1,...,y_n \}## is a basis for ##V##. By extending the ##x## vectors, do you think he was just referring to including all the ##y## vectors in the set of ##x## vectors that are linearly independent of the ##x## vectors?
Thanks!
If you have a set of linearly independent vectors, you can expand that set into a basis simply be adding more vectors. In your example, you can choose ##x_{k+1}## as any vector in V that is not in the span of ##\{x_1, \dots x_k \}##.
And then, any vector ##x_{k+2}## that is not in the span of ##\{x_1, \dots x_{k+1} \}##.
Until you have a basis of ##n## linearly independent vectors.
OK cool, that's what I thought but I wanted someone else's perspective! Thanks PeroK!
##\textbf{Exercise 10}:## I came across the following solution online: Questions: 1. When the author states in "that ring (not sure if he is referring to ##R## or ##R/\mathfrak{p}##, but I am guessing the later) ##x_n x_{n+1}=0## for all odd $n$ and ##x_{n+1}## is invertible, so that ##x_n=0##" 2. How does ##x_nx_{n+1}=0## implies that ##x_{n+1}## is invertible and ##x_n=0##. I mean if the quotient ring ##R/\mathfrak{p}## is an integral domain, and ##x_{n+1}## is invertible then...
The following are taken from the two sources, 1) from this online page and the book An Introduction to Module Theory by: Ibrahim Assem, Flavio U. Coelho. In the Abelian Categories chapter in the module theory text on page 157, right after presenting IV.2.21 Definition, the authors states "Image and coimage may or may not exist, but if they do, then they are unique up to isomorphism (because so are kernels and cokernels). Also in the reference url page above, the authors present two...
When decomposing a representation ##\rho## of a finite group ##G## into irreducible representations, we can find the number of times the representation contains a particular irrep ##\rho_0## through the character inner product $$ \langle \chi, \chi_0\rangle = \frac{1}{|G|} \sum_{g\in G} \chi(g) \chi_0(g)^*$$ where ##\chi## and ##\chi_0## are the characters of ##\rho## and ##\rho_0##, respectively. Since all group elements in the same conjugacy class have the same characters, this may be...
