Expansion of a plane wave in spherical waves
clive
I have to expand a plane wave in spherical waves by using
e^{i\vec{k}\cdot\vec{r}}=\sum_{n=0}^{\infty}i^n (2n+1)P_n(cos \theta) j_n(kr)
I wrote a MATLAB code (pasted below) in order to check this by plotting the two sides of the eq above. The graphs are similar but different. I do not know what is wrong with this ... I suppose there are some missing coefficients somewhere...?
clear all;
close all;
clc;
kr=0.1*i+6;
x=linspace(-1, 1, 100);
for(ii=1:100)
F_plane(ii)=exp(i*abs(kr)*x(ii));
end
for(ii=1:100)
F_approx(ii)=0;
for(order=0:150)
ASSOCLEG=legendre(order, x(ii));
F_approx(ii)=F_approx(ii)+i^order*(2*order+1)*besselj(order, abs(kr))*ASSOCLEG(1);
end
end
plot(x, real(F_plane), 'or', x, imag(F_plane), 'ob', x, real(F_approx), '-r', x, imag(F_approx), '-b')
I have the same problem, does anyone what is missing here?
Is this for school or for work? I can move the thread to the Homework Help forums if its homework/coursework.
This is for school
I figured out that the problem is that in your code you are using besselj in MATLAB which is ordinary bessel function of first kind (J_n). You should have used spherical bessel functions j_n instead in this expansion.
The spherical Bessel functions j_n are given in terms of ordinary Bessel functions J_n by:
j_n(x) = sqrt(pi/(2*x)) J_{n+1/2}(x)
This would solve it
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
