Can you help me solve for the value of A in the expansion of (x^2 - 2)^5?
  • Thread starter Thread starter wayneo
    Expansion
The discussion focuses on solving for the value of A in the expansion of (x^2 - 2)^5. It clarifies that the number of terms in the expansion is 6, as indicated by the binomial theorem, which states that an expansion of power n has n+1 terms. The first four terms of the expansion are given as x^10 - 10x^8 + 40x^6 + Ax^4. To find A, participants suggest using the binomial expansion and Pascal's triangle to calculate the coefficients, ultimately revealing that A equals -80. Understanding these concepts is essential for accurately determining the expansion's terms and coefficients.
wayneo
This is a question from a test that I have done. I have the answer but am unsure of the working.
consider the expansion of (x^2 - 2)^5
a) write the down the number of terms in this expansion
b) the first 4 terms of the expansion in descending powers of x are
x^10 - 10x^8 + 40x^6 + Ax^4 + ...
Find the value of A
For part a) I got the answer as 5 but apparently it is 6 and I am not sure why.
I am stuck how to do part b) but know the answer is -80
Well you can either use the binomial theorem, or multiply it all out yourself and see why there are 6 terms and A is -80.
Find the value of A
Do you know pascals triangle? If you look down to the sixth row there are 6 numbers, hence your expansion has 6 terms. You can think of it like this: a quadratic has 3 terms, a cubic has 4 terms etc. As a rule if you have an expansion to the power n there will be n+1 terms (assuming none of the terms cancel out.)
For part B you will have to use the binomial expansion. You will need to use pascals triangle or "choose" notation to calculate the multiplier and then use the fact that the sum of the powers of each term on the right needs to equal the power on the left (IE if the x^2 is cubed then the -2 needs to be squared.) With these two things you should calculate the right answer.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
