Expectation Of The Maximum When One Of The Random Variables Is Constant
The discussion centers on calculating the expected value E[X] for a device's failure time, where X = max(T, 2) and T is exponentially distributed with a mean of 3 years. The proposed solution involves integrating over two intervals: from 0 to 2, where the value is constant at 2, and from 2 to infinity, where it equals T. Clarifications are sought regarding the integration limits and the reasoning behind including the constant in the first integral. Participants debate the correctness of the solution, with some suggesting adjustments to the integration results. The conversation highlights the complexity of dealing with constant random variables in the context of order statistics.
actcs
Good Evening:
I'm given this problem:
A device that continuously measures and records seismic activity is placed in a remote
region. The time, T, to failure of this device is exponentially distributed with mean
3 years. Since the device will not be monitored during its first two years of service, the
time to discovery of its failure is X = max(T, 2) .
Determine E[X].
Solution: 2 + 3 Exp[-2/3]
I've even got the procedure
It's:
E[X] = Integral From 0 To 2 [ 2*f(t)dt ] + Integral From 2 To Infinity [ t*f(t)dt ]
Where f(t)=1/3 Exp[-1/3 t]
I Just want to know, why is this?... Why the interval of the first integral is from 0 To 2, and then again that "2" appears in the integral?... I tried to calculate by means of order statistics but result didn't match
Does someone know how to prove this is actually the solution?... (I'm certain this is the correct solution, but I just want a more specific and justified procedure. I'm not familiarized with constant random variables)
Thanks in advance
Good morning, actcs! :smile:
Because E[X] = ∫ X(t) f(t) dt.
So when X(t) is a constant, K, over an interval, the integral over that interval is ∫ K f(t) dt …
and in this case K = 2. :wink:
(and ∫ f(t) dt, without the K, would just be the probability, not the expectation)
Hello, Thank you for replying
The problem in this case is that the constant random variable is involved in an order statistic, so it is not so trivial to see the sample space of each of the random variables
I did this: Write the random variable X as:
X = 2 I(0,2](T) + T I(2,Infinity)(T)
Where I(a,b)(T) is an indicator function for the random variable T
The way I see this was:
If device fails between now and the end second year, discovery time will be "End of year 2", whereas if device fails after that, discovery time will match fail time, ie, X=T
I think it was rather complicated to obtain the density funcion of X and then calculate the expectation
Best Regards
It's:
Thanks in advance
I don't think that is the correct solution since:
Integral from 0 to 2 of Exp[-1/3 t]= -Exp[-1/3 t]-(1)=1-Exp[-1/3 t]
Therefore your solution should be:
E[X] = 2 [1-Exp[-1/3 t]] + Integral From 2 To Infinity [ t*f(t)dt ]
I said that solution was
Which is almost the same as you posted
It should be:
E[X] = 2 [1-Exp[-2/3]] + Integral From 2 To Infinity [ t*f(t)dt ]
Best Regards
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
