How Do You Calculate the Expectation Value of Momentum in Quantum Mechanics?
atomicpedals
I've managed to get myself confused on a seemingly simple point of mathematics. When I calculate the expectation value of momentum in quantum mechanics
<p>=\int{\psi* \frac{\hbar}{i} \frac{d}{dx} \psi dx}
To what should I be applying the derivative? \psi?
Of course you would apply it to ψ. What else?
Order of operation would rule out complex conjugate of \psi. So, instead of being like <x> which can simplify to
&lt;x&gt;=\int{|\psi|^{2}xdx}
it would instead be
&lt;p_x&gt;=\int{\psi * \frac{\hbar}{i} \frac{d \psi}{dx} dx}
it would instead be
Yes. That's it.
Right on, thanks.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
