Expectation Value of x: Definition & Meaning
In summary, the expectation value is defined as the average of repeated measurements on an ensemble of identically prepared systems, where the probability density must be the same in all experiments. This is similar to the concept of rolling a dice in statistics, where the dice must be identical in all experiments. However, the density matrix formalism is used in cases where the dice (or quantum state) is uncertain, and it can be thought of as a double dice setup with a classical dice determining the quantum dice. From this definition, <\psi|x|\psi> can be derived as one method of calculating the expectation value.
pardesi
339
Griffith said:
The expectation value is the average of repeated measurements on an ensemble of identically prepared systems
How does this follow from the defintion of the expectation value of x
Just as in ordinary theory of probability. Just change wavefunction to probability density function.
i am not able to get the importance of identically prepared systems
compare it with the dice example in statistics, the dice must be indentical in all the "experiments". i.e the probability density must be the same in all experiments.
What if you first have a dice with perfect 6 sides in the first experiment, then in the 4435th you switch to a dice which does not have 6 perfect sides, but prefers to show 4?
It's just basic theory and definition of probability theory.
In case it isn't clear after malawi_glenn's response, another good question that might bother you is that, OK the statistics refers to the same dice, but the real question is how do you KNOW that dice is the same?
You might argue that in many realistic cases you don't.
Then the supposed solution to those cases is the density matrix formalism(http://en.wikipedia.org/wiki/Density_matrix), which can be thought of as a classical type probability distribution over the possible quantum states (Here the dice is the quantum state). So I think of it intuitively as a double dice setup. A classical dice, which you throw to see what quantum-dice you get. So each "face" of the classical dice, is actually a quantum-dice, which can then be thrown.
The case where you know (left alone HOW you acquired this knowledge with certainty) that the dice(really meaning quantum state) is determined, is called a pure state. If the dice is uncertain it's a mixed state.
/Fredrik
You have it backwards.
"The expectation value is the average of repeated measurements on an ensemble of identically prepared systems" is the definition.
From the definition, you can derive [tex]<\psi|x|\psi>[/tex] as one method of calculating the expectation value.
Just expand in the basis of eigenstates and note that the right-hand side is the weighted average of all the eigenvalues:
[tex]\langle\psi|A|\psi\rangle=\sum_a\langle\psi|A|a\rangle\langle a|\psi\rangle =\sum_a a\big|\langle a|\psi\rangle\big|^2[/tex]
1. What is the definition of expectation value of x?
The expectation value of x is a mathematical concept used in quantum mechanics to describe the average value of a physical quantity, such as position or momentum, in a given state of a system. It is represented by the symbol ⟨x⟩ and is calculated by taking the sum of the product of the possible values of x and their respective probabilities.
2. How is the expectation value of x calculated?
The expectation value of x is calculated by taking the integral of x multiplied by the probability density function, or by summing the product of the possible values of x and their respective probabilities.
3. What does the expectation value of x represent?
The expectation value of x represents the average value of a physical quantity, such as position or momentum, in a given state of a system. It is not necessarily the actual value that will be measured, but rather the most probable value.
4. How is the expectation value of x related to uncertainty?
The expectation value of x is related to uncertainty through the Heisenberg uncertainty principle, which states that the product of the uncertainties of two complementary physical quantities, such as position and momentum, must be greater than or equal to the reduced Planck's constant divided by 2.
5. Can the expectation value of x be negative?
Yes, the expectation value of x can be negative. This indicates that there is a higher probability of the physical quantity having a negative value rather than a positive one. However, the expectation value itself is a measure of the average value and does not necessarily represent the actual value that will be measured.
  • Quantum Physics
  • Quantum Physics
