Can I Use Magnets to Create a Temperature-Sensitive Pendulum?
In summary: Quite a long way.In summary, the experiment described is not perpetual motion, and there is no way to make it work.
AlchemistK
158
I have two quite powerful magnets that i took from a microwave magnetron.
Are there any interesting experiments or activities i could do with them? Maybe be costruct something?
Something that I might try is to create a "perpetual" machine. Magnets become less magnetic when they are heated (but check to make sure that yours get it back! Some do NOT). If you set up a magnet on a pendulum, then, off to one side of the swing, put a candel. Then, set up another magnet above the candle, so that it is not being heated too much but is able to bring the first magnet to it. The hanging magnet will be pulled to the other one, but the candle underneath will heat it up, causing it to become less magnetic. It falls down, cools, and the cycle starts again.
Perpetual motion discussion isn't allowed at PF.
The description of the device you have given won't work. Period.
It is not perpetual motion, hence the quotes. It needs to be constantly fueled with a candle, which, of course, is a consistent input of energy.
Perpetual motion does not imply free energy. That would be an over unity device.
Perpetual motion simply means it will keep going without stopping.
Regardless, the design of the system proposed will not work.
EDIT: I suppose I could be taking the definitions of the words too literally. In which case, quotes accepted.
There is a similar 'perpetual motion' toy which consists of a bird made of blown glass. It dips its beak, repeatedly into a bowl of water without any apparent source of energy. The 'engine' works from the latent heat of vaporisation of the water on the bird's beak which condenses and evaporates some alcohol inside the bird and alters the balance. The room supplies the energy, ultimately.
But would the suspended magnet cool down enough in the short 'swing' time for this to be effective and actually work?
Never tried it myself, but apparently it does.
You could do a magnetic pendulum, such as this:
http://www.bytelove.com/stuff/gadgets/romp/prod_95.html
There would be many 'cooling' swings, once the Curie Point was reached and the main magnet let go. Only when the magnet cooled enough down would it be attracted back towards the main magnet.
It would cool down enough, because, if you think about it, it only starts cooling the second it's too far away. Then, it is immediately pulled back up. Of course, correct placement is required.
I'm not convinced, this is one I'd like to see in action.
EDIT: Job done -
Rather disappointing to be honest. Was hoping for more pendulum action.
I agree - a bit disappointing. It's all a bit light weight to be impressive.
It will all be a matter of time constants. If the swinging magnet is bigger (stronger and more massive), I think there will be more of a lag in the temperature changing and it will get a chance to swing further away before it goes below TCurie and gets pulled back.
I guess you need to have it suspended so that it is 'just' attracted to the big magnet when cold and the candle needs to be 'only just' powerful enough to heat it up. Then, once it's been let-go, it won't be pulled back until it's had time to cool down a lot.
1. How do magnets work?
Magnets work by creating a magnetic field around them, which is caused by the alignment of electrons in the magnet. This magnetic field attracts or repels other magnets or magnetic materials.
2. What is the best way to conduct an experiment using magnets?
The best way to conduct an experiment using magnets is to have a clear hypothesis, carefully control all variables, and use a variety of materials and distances to test the effects of the magnet.
3. How can we measure the strength of a magnet?
The strength of a magnet can be measured using a magnetometer, which detects the magnetic field of the magnet. Another way is to use a spring scale to measure the force needed to pull the magnet away from a metal object.
4. Can magnets lose their magnetism?
Yes, magnets can lose their magnetism over time due to exposure to high temperatures, strong electromagnetic fields, or physical damage. However, some magnets, like neodymium magnets, are more resistant to demagnetization.
5. What are some real-life applications of magnets?
Magnets have a wide range of real-life applications, including in generators, motors, speakers, hard drives, credit cards, and medical equipment such as MRI machines. They are also used in everyday objects like refrigerator magnets and door latches.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
