I Experimental bound on the scalar spectral index
The discussion revolves around the scalar spectral index, specifically the value of n_s = 0.9655 ± 0.0062 from the Planck 2013 data, which is questioned for its citation in Visinelli's 2016 paper. Participants note that the 95% confidence region mentioned by Visinelli lacks a specified range, leading to confusion about its derivation from the Planck results. The Gaussian approximation suggests that the 95% confidence bound could be roughly double the 68% bound, providing a potential range for n_s. Additionally, there are concerns about a possible typo in Visinelli's equation regarding n_s, but the impact of this error is deemed minimal. The conversation emphasizes the need for clarity on the 95% confidence limits and the implications of the cited data.
shinobi20
Based on the paper by Visinelli (https://arxiv.org/abs/1605.06449),
He stated in page 6 that the scalar spectral index as given by the Planck 2013 data (https://arxiv.org/abs/1303.5076) is,
##n_s = 0.9655 \pm 0.0062~~## (##68\%## C.L.)
but when I looked into the Planck 2013 paper, I did not see that constraint, so I tried to read the much later paper by the Planck team which is the Planck 2015 (arxiv.org/abs/1502.02114) and I saw it, also it is very strange for Visinelli to cite the 2013 results given that his paper had been published in 2016, so it makes more sense for him to cite the 2015 paper by the Planck team.
The problem is, he also stated in Figure 1. on page 13 that "the light blue band showed the ##95\%## confidence region" but he did not state any range for it unlike the ##68\%## above. I tried to search for it in the Planck 2013 and 2015 paper but I can't seem to find the range given by the Planck team for the ##95\%## confidence region. Can anyone help me with this?
Also, I noticed that in Visinelli's paper, equation (3.10) seems wrong, I think it should be ##n_s -1## instead of ##1-n_s## since if you try to compute for ##n_s## it would give an answer that is out of the range (far out). Any comment?
Space news on Phys.org
The ##1-n_s## looks like a typo to me as well, as all of their other equations on the page put it in terms of ##n_s-1##. But since ##n_s-1 = -(1-n_s)##, the end result won't be that dramatic if it's wrong: you'd get ##n_s = 1.0345## instead of ##n_s = 0.9655##.
I wouldn't worry too much about them using the older result. They were probably working on the paper for a while, and when they started the new results weren't out. Or it could be a simple oversight. Either way, a slight difference in the value and error bars shouldn't make much difference to the results.
Thanks for that but my question is where to find the ##95\%## C.L. bound for ##n_s##? How did they come up with that if the Planck paper did not mention it?
Why do you need the 95% confidence bound?
In the Gaussian approximation, the 95% confidence bound will be approximately twice the 68% confidence bound. One solution may be to just estimate it yourself using the released data products, but that's a pretty big task to perform.
I don't know what the author actually did, but this does give the result shown in Figure 1 of the paper.
In more detail, assume: 1) Gaussian; 2) ##n_s = 0.9655 \pm 0.0062## (68.27% CL). These assumptions then give that ##0.0062## is one standard deviation, and that the 95.45% CL is given by two standard deviations. Consequently, ##n_s = 0.9655 \pm 0.0124## (95.45% CL), i.e.,
$$0.9531 < n_s < 0.9779,$$
which are the bounds in the figure.
Likes Greg Bernhardt
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
The formal paper is here. The Rutgers University news has published a story about an image being closely examined at their New Brunswick campus. Here is an excerpt: Computer modeling of the gravitational lens by Keeton and Eid showed that the four visible foreground galaxies causing the gravitational bending couldn’t explain the details of the five-image pattern. Only with the addition of a large, invisible mass, in this case, a dark matter halo, could the model match the observations...
Hi, I’m pretty new to cosmology and I’m trying to get my head around the Big Bang and the potential infinite extent of the universe as a whole. There’s lots of misleading info out there but this forum and a few others have helped me and I just wanted to check I have the right idea. The Big Bang was the creation of space and time. At this instant t=0 space was infinite in size but the scale factor was zero. I’m picturing it (hopefully correctly) like an excel spreadsheet with infinite...
