What are the effects and explanations of blue shift and red shift?
  • Thread starter Thread starter Koveras00
    Effects
Blue shift and red shift refer to the changes in frequency of light due to motion or gravitational effects. Blue shift occurs when light's frequency increases, typically as an object moves closer, while red shift indicates a decrease in frequency, often due to an object moving away or the expansion of space. Astronomers use spectral lines to identify elements like hydrogen, comparing observed frequencies to known laboratory values. A redshift measurement, denoted as "z," quantifies the change in frequency or wavelength. For instance, a redshift of z = 0.1 indicates a ten percent decrease in frequency, suggesting the emitting object is receding at approximately one-tenth the speed of light or that space has expanded during the light's journey. This concept is crucial for understanding cosmic expansion and the movement of celestial bodies.
Koveras00
Can anyone explain what is blue shift and red shift?? And what effects they have?
blue shift and red shift are the astronomers' words for
frequency shifts up or down
blue shifted light is light with the frequency shifted up
(by motion towards, doppler-fashion)
redshifted light is light with the frequency shifted down
(either by motion away, doppler, or by the expansion of
the space in between, or by a gravity effect)
the light from each kind of atom has a distinctive recognizable pattern of spectral lines, so if you see some hot hydrogen gas you can recognize that it is hydrogen and you can tell (from measurements in the laboratory with the same gas) what
frequencies it OUGHT to be emitting.
So if you measure the light that is actually getting to you and find that it is redshifted by ten percent (frequency ten percent lower, or wavelength ten percent longer) then you say "z = 0.1"
z is the conventional symbol for the redshift, the fractional (increase in wavelength, or) decrease in frequency. So a ten percent decrease in frequency means "z = 0.1".
And that corresponds to the doppler effect of motion away by approximately one tenth of the speed of light.
Or a ten percent stretchout of space during the time the light was on its way to you.
There are some fine points and an improved doppler formula and some ambiguities about what is relative motion away and what is the expansion effect, but basically the redshift z = 0.1 would be interpreted as nearly all due to a tenpercent expansion of space during the light's passage and it would be informally talked about as if it were due to the emitter moving away at one tenth the speed of light.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
