JesseM said:
for a more general proof about when the constant-G approximation works, I came across this paper
http://arxiv.org/abs/physics/0310049
The paper does show that you need a few extra conditions ...
...I don't think it's always true in GR,
RandallB said:
Are we starting to waffle here ?
Are you about to say you didn’t intend assumptions to actually be accurate?
Not waffling, just admitting that I was wrong about the correct definition of the limit--it's not just the limit as the height becomes small compared to the radius of the planet, but also the limit as the horizontal distance becomes small compared to the radius, and the maximum curvature of the curve does
not become small compared to the curvature of the planet. In my defense, I had mainly been thinking about the simplest case where the ball is tossed vertically and it's the graph of position vs. time that you want to approach a parabola--in this case, the only limit you need to worry about is the height being small compared to the radius of the planet.
As for my second statement that "I don't think it's always true in GR" (referring to planets traveling in ellipses), if you think this is "waffling" you haven't been paying attention to my earlier posts, I've said all along that elliptical orbits would only be valid in GR as an
approximation in the Newtonian
limit. For example, in post #38 I said:
I think the real path is only an ellipse if you use Newtonian gravity, which is just as much of an approximation as the constant G-field is. We know that GR predicts Mercury's orbit is not a perfect elipse--the perihelion changes slightly with each orbit--so I would assume that this effect does not just vanish abruptly at some point, presumably if you calculated the exact path of a tossed ball which was able to travel straight through the earth, its perihelion would precess slightly too. Of course the difference from the Newtonian prediction and the GR prediction might be only a nanometer with each orbit or something, but the difference between the constant-G prediction of a ball's path between the time it is tossed and the time it hits the ground again would probably also differ from the decreasing-G prediction by only a microscopic amount (do you admit, by the way, that your earlier statement 'If you take air resistance out of it you will completely change the shape of the curve' was incorrect?)
Then in post #40 I emphasized this point many times:
JesseM said:
Just like GR doesn't say curves are exactly elliptical[/color], although they are approximately so. If he had asked how GR explains elliptical paths, would you just thunder that GR "DOES NOT" predict such paths, or would you understand that he was speaking approximately?
RandallB said:
Originally Posted by RandallB
And sure you need me to say it twice? IN A VACUUM IT’S ELLIPTIC not parabolic!
Not exactly, according to GR--again, think of the precession of the perihelion of Mercury's orbit, showing that the orbit is not a perfect ellipse. But the ellipse is a valid
approximation because in the Newtonian
limit the orbit predicted by GR becomes arbitrarily close to an ellipse.
For example, do you think it is ever justified to use Newtonian mechanics when we know that these predictions differ slightly from those of GR (for example, GR will say that a planet's orbit is not precisely elliptical[/color]), and that GR's predictions are the more accurate ones?
I don't say that Newton or GR produce a parabolic exactly, just like GR doesn't produce elliptical orbits exactly. Once again,
are you completely unfamiliar with the concept of approximations based on limits?
And in post #45 I repeated this:
JesseM said:
RandallB said:
GR reduces to the Newtonian in our real world
Not exactly, no--only in the limit. In any real example, there will be a slight difference between GR's prediction and the Newtonian prediction. Do you disagree?
OK, back to your post:
JesseM said:
For the millionth time, do you have no understanding of the difference between exact results and approximations based on limits? the parabolic path is a perfectly good approximation even though it is never exactly correct for any finite height, just like Newtonian orbits are perfectly good approximations for GR
RandallB said:
I question your counting as much as I disagree with the usefulness these approximations limits or otherwise.
Whether it is "useful" or not is not the issue here, the issue is just whether the notion of an approximation becoming arbitrarily close to accurate in a certain limit is a
mathematically rigorous one, and it is. You're free to accept this but still not use these approximations because "anything less than perfect accuracy is EEEVIL" or whatever, although I'll note again that if this is your attitude it's hypocritical of you to say Newtonian mechanics is appropriate to use in
any situation (even, say, planetary orbits), because we know it always differs slightly from the predictions of GR, even the difference between Newtonian predictions and GR predictions becomes arbitrarily small in certain limits. Again, I'm pretty sure that GR would say the orbits of planets are never
exactly elliptical, so that'd be an example of what I'm talking about.
RandallB said:
Just look at the web DOC you suggested – see figure 1
The diagram on the left cuts out a section of an ellipse that looks much more like a hyperbolic than a parabolic. But then the less than faithful redrawing in a “flat” frame on the right might look parabolic, so what if you can distort the view to make look like anything someone wants.
In the
limit as the width and height of the region you're considering becomes arbitrarily small compared to the radius of the planet, the polar coordinates become arbitrarily close to cartesian coordinates--for example, the angle between different radial lines in the polar coordinate drawing approaches zero in the region, and the curvature of the constant-radius lines approaches zero in the region. Do you disagree?
RandallB said:
You aren’t going to let that pass as real science when they already plainly agree the true path is an ellipse are you?
For the last time Randall,
I agree the true path in Newtonian mechanics is an ellipse too, my argument (and theirs) is just that in a certain well-defined limit, the true elliptical path becomes
arbitrarily close to the approximate parabolic path. Similarly, in GR the true path of an orbit is
not an ellipse, but in a certain well-defined limit, the true non-elliptical path predicted by GR becomes
arbitrarily close to the elliptical path predicted by Newtonian mechanics.
RandallB said:
The point of the paper is complaining that most texts do a bad job of defining hyperbolic curves at low speeds! Are they talking about CREN??
The CERN page did not even attempt to define what the appropriate limit is where the parabolic approximation becomes valid, it just took for granted that tossing a ball on Earth is a situation where it's fine to use this approximation, and the paper would validate this assumption, even if the authors may feel it's important to make the nature of the limit explicit.
RandallB said:
And then inexplicably to me they proceed to interpret a parabola from the apogee of an ellipse! Parabolas don’t have an apogee just a perigee!
So what? The point is that the apogee of the ellipse becomes arbitrarily close to the perigee of the approximate parabola in this limit, and they demonstrate this mathematically. There's no rule that says it must be the perigee of an ellipse which approaches the perigee of a parabola in the limit. If you disagree with their proof, please point out which step you think is incorrect.
RandallB said:
Why don’t they use the IDENTICAL in shape “parabola” cut from the other side of the ellipse they display at perigee!
Why should they? The perigee would be somewhere deep beneath the surface of the earth, and would have no relevance to the question of whether the portion of the path immediately above the surface becomes arbitrarily close to a parabola in some limit. In any case, if mathematics proves that the apogee of an ellipse becomes arbitrarily close to the perigee of a parabola in some well-defined limit, it doesn't make any sense to "dispute" this proof by spluttering "but one is an apogee and the other is a perigee!"
RandallB said:
Then describe a “parabolic” path displaying some kind of negative gravity as the ball is rising in altitude!
Er, what? If the initial velocity of the ball at the surface is in the upward direction, then of course it will rise (this is just as true of the elliptical path as it is of the parabolic approximation), positive gravity just says that everything must
accelerate towards the Earth (as the ball is doing, since its upward velocity is decreasing as it goes up), not that every object's
velocity must point towards the Earth at all moments. "Negative gravity" would be if it was accelerating upwards, ie if its velocity away from the Earth was increasing as it travelled.
RandallB said:
Their concluding proviso that it shouldn’t apply for speeds much less than escape?
That's not an additional proviso, they just say that this proviso is
equivalent to the condition on the radius of curvature of the object's path vs. the Earth that they mentioned earlier, namely \alpha \epsilon << 1.
RandallB said:
They really mean speeds much less than circular – this is just a pure diversion from the reality. I consider it no more than a magician’s need to justify a misdirection even if it has fooled themselves as well.
Why is this a "misdirection"? As they say earlier in the paper, "The condition \alpha \epsilon << 1, then, is simply the condition that the motion is very slow compared to typical “orbital” (as opposed to “trajectory”) motions." Would you disagree that a ball tossed by human hands near the surface of the Earth will have a velocity very small compared to that of a ball orbiting the earth?
RandallB said:
I’ve already covered the point that a segment of an ellipse can look like part of a circle now here we have what looks like a hyperbola till they distorted it to seem like a parabola. SO WHAT, who cares that you can contort the measuring frame to make something like else. Don’t you want to deal with reality?
I know of no well-defined limit where the elliptical path predicted by Newtonian gravity can be shown to become arbitrarily close to a circular path--do you? This certainly would not be true in the case of the limit they discuss in their paper, where the height and horizontal path length are very small compared to the radius of the planet, and the maximum curvature of the path is much greater than the curvature of the planet.
RandallB said:
The graininess of observation (approximation) here required to fail to see elliptical paths is huge by miles more than the graininess of the mercury observations – so stop making that comparison it’s just foolish.
No it isn't. Again, I'd be happy to look at an actual numerical example where we consider a ball tossed with a small initial velocity, and find the difference between the exact elliptical path and the approximate parabolic path at a bunch of different points along the trajectory. I am confident we'd find that the difference is microscopic--so again, if you take me up on this offer, then
please tell me in advance whether you'd reconsider your position if it turns out I'm correct that the difference would be microscopic in such an example. I would certainly reconsider
my position on the usefulness of this approximation if it turned out the difference was non-microscopic (I would not reconsider the position that as the height and horizontal length of the path becomes
arbitrarily small compared to the radius of the planet, the parabolic approximation becomes arbitrarily close to perfect, but if it turned out the difference was non-microscopic in the case of a ball tossed a few meters than I'd conclude that this height was not close enough to 'arbitrarily small' compared to the radius of the Earth for the approximation to be useful for typical examples).
RandallB said:
Of course what’s hard about that and why do you continue to define a tossed ball by it’s vertical direction or speed?? That is totally meaningless here. When defining your toss, I don’t care what angle – the only thing we need is its horizontal speed at apogee or perigee when vertical speed reaches zero. So just pick a horizontal speed to start with and pitch it flat to the north from the equator. To see the whole curve just toss a ball north and a second ball south same speeds what’s the problem, you can’t be worried about air resistance.
OK, I see what you're saying--you want two balls tossed in opposite directions from their maximum height, with their vertical velocity set to be zero at the moment they're tossed. Yes, then the two balls together will give the same curve as a ball tossed upwards and horizontally from the surface with a certain velocity--but if the two situations give the same path, what difference does it make? Perhaps you're just suggesting that we start from the apogee because it's easier to calculate the equation of the elliptical path with this information?
JesseM said:
What exactly is a "limit line"?
RandallB said:
A parabolic trajectory is on a path to reach “apogee” 180 on the opposite side of the Earth (or main body being orbited) that apogee on a straight line from our stating perigee point though the center of orbit as a major axis to whatever distance needed to reach the apogee point. Just like the elliptic path that as that orbit moves away from the major axis it cannot start to move back towards it until the tangent of the path is parallel to that major axis line at some distance from it. The point at which it does become parallel defines the mid point of the ellipse and the crossing point for the minor-axis making a perpendicular line across the major-axis to reach the point where the ball tossed the other way has also reached a parallel tangent in its path. The issue with a parabolic is it can never move toward an apogee or even back towards what would be the major axis as its tangent never reaches this line except as a limit at infinity. What are you using to define the limit of this parabolic, if it’s an asymptote what do you use as references to it? Does it ever become perpendicular to the Earth's surface? – how and when?
You're talking about what would happen to the ball after it falls right through the surface of the earth, but in case I haven't made this clear, the parabolic approximation is only supposed to become arbitrarily close to the true elliptical path
for the small subsection of the path above the surface of the earth, I completely agree that the parabolic path will begin to wildly diverge from the elliptical path if you extrapolate it through the crust and down past the center of the earth! In this case, as you say, the elliptical path will eventually turn around and start approaching the major axis again, finally hitting it at the perigee, while the parabolic path will never do so. The approximation was never meant to hold for such an extrapolated path, just for the section of the path that is actually physically meaningful for a ball tossed near the surface (since a real ball won't be able to travel right through the surface of the Earth like a neutrino).
RandallB said:
As I said before, but not a million times yet, GR only predicts a parabola at escape velocity not at lower speeds. Galileo’s parabolas require air resistance.
And as I've said, the fact that the path of a tossed ball looks like a parabola has nothing to do with air resistance. Again, if we were to actually calculate the difference between an elliptical path and a parabolic path for a ball tossed above the surface (
not continuing the paths past the surface) at ordinary velocities, I am confident that the difference will be microscopic. Are you willing to actually look at such an explicit numerical calculation and reconsider your position if it turns out I am right?
