A Can Gamma Functions Be Evaluated Analytically for Non-Integer Values?
LagrangeEuler
I have two questions related Gamma functions
1. Finding ##\Gamma## analytically. Is that possible only for integers and halfintegers? Or is it possible mayble for some other numbers? For example is it possible to find analytically ##\Gamma(\frac{3}{4})##?
2. Integral ##\Gamma(x)=\int^{\infty}_0 \xi^{x-1}e^{-\xi}d \xi ## converge only for ##x>0## in real analysis. How can we then write ##\Gamma(\frac{1}{2})=\Gamma(-\frac{1}{2}+1)## when relation ##\Gamma(x+1)=x\Gamma(x)## is derived from partial integration?
How about to use Gauß' formula for ##x \in ℂ \backslash \{0, -1, -2, \dots \}## instead:
$$Γ(x) =\lim_{n→\infty} \frac{n!n^x}{x(x+1) \cdots (x+n)}$$
Edit: It's sufficient to require ##Re(x) > 0## for the integral formula.
The gamma function has singularities at 0 and negative integers. Using analytic continuation the function can be defined elsewhere.
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
