Why Does Angular Momentum Use a Cross Product Instead of a Dot Product?
Angular momentum is defined using a cross product because it incorporates the direction of the vectors involved, specifically the position vector and momentum vector. The formula r x p reflects the perpendicular relationship between these vectors, which is essential in determining the rotational effect. In contrast, a dot product does not account for direction, making it unsuitable for angular momentum calculations. The use of a cross product ensures that the resulting angular momentum vector is orthogonal to the plane formed by the position and momentum vectors. This fundamental distinction is crucial for accurately describing rotational dynamics.
CrazyNeutrino
Can someone please explain why angular momentum involves a cross product?
Why is it r x p and not r . P
Why a cross product and not a dot product?
Hi,
Angular momentum involves a perpendicular direction, i.e. in general when you take direction into account, it should be a cross product. In dot product no direction.
Cheers, Rajini
Likes larsa
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
