How is Diamond Revolutionizing MEMS Technology?
  • Thread starter Thread starter g0ggs123
    Diamond Mems
Diamond is increasingly recognized for its potential in MEMS applications, particularly in enhancing the durability and performance of devices like AFM tips. Microwave plasma CVD is favored for diamond coatings due to its ability to produce consistent thin films, though the effectiveness of PVD is also acknowledged. The discussion highlights that a carbon-diamond structure may offer advantages in surface finish, potentially reducing the need for post-machining. While cost is a significant barrier, other disadvantages are less clear and may vary across different MEMS categories. Further research into specific MEMS branches and existing literature is recommended for deeper insights.
g0ggs123
Hi I am doing a research project into the use of diamond in MEMS and I've got a few questions for anyone who knows a bit about this field:
1) What are the major uses of diamond in MEMS (I haven't found nearly as many as I would have expected)?
2) Is Microwave plasma CVD the best way for coating elements such as Silicon with diamond in thin film coatings? Is PVD as good as CVD?
3) Is there any advantage of coating with a carbon-diamond structure rather than fully diamond to get say a finer surface finish and thus less after-machining?
4) What are the major disadvantages other than cost which can be ignored in this field?
These are some pretty broad questions you are asking. There are many categories of MEMS and one material might have a particular advantage in optical MEMS that is a disadvantage in BioMEMS. So maybe focusing your research on a particular branch of MEMS technology will help focus your research more.
Also what research have you done so far? What do you know?
Here are some good papers on using diamond materials in MEMS
1) Shibata, T.; Kitamoto, Y.; Unno, K.; Makino, E., "Micromachining of diamond film for MEMS applications," Microelectromechanical Systems, Journal of , vol.9, no.1, pp.47-51, Mar 2000
This describes an AFM tip that uses diamond material structure. Diamond is useful in this application because it help improve the lifetime of the AFM tip.
2) A. R. Krauss, O. Auciello, D. M. Gruen, A. Jayatissa, A. Sumant, J. Tucek, D. C. Mancini, N. Moldovan, A. Erdemir, D. Ersoy, M. N. Gardos, H. G. Busmann, E. M. Meyer, M. Q. Ding, Ultrananocrystalline diamond thin films for MEMS and moving mechanical assembly devices, Diamond and Related Materials, Volume 10, Issue 11, November 2001, Pages 1952-1961,
This paper can give you some general advantages that diamond material can have in a MEMS device, though it will be up to you to dig further to determine what technologies these advantages can be applied to.
3) E. Kohn, P. Gluche, M. Adamschik, Diamond MEMS -- a new emerging technology, Diamond and Related Materials, Volume 8, Issues 2-5, March 1999, Pages 934-940,
This paper will help you understand some of the trade offs using CVD vs PVD to deposit materials.
Read through these papers and ask questions based on that research.
Cheers for the papers had read one of them already but the other two were very useful,
Is it true that a resist cannot be used with diamond mems since the main processes for producing a film rely on the CVD method which gives a consistent coating over the entire substrate regardless of a resist?
Also if DLC is used as a thin film can the sputtering process be used to create the film in which case a resist can be used to protect some of the substrate and thus create a pattern if the resist is patterned?
Any help would be greatly appreciated
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
