How can a projection matrix be used to solve an exponential matrix equation?
  • Thread starter Thread starter Sigurdsson
    Exponential Matrix
Sigurdsson
Show that
e^{tA} = I - A + e^{t}A
t \in T \ \ \ \ T \subset R
R being the set of real numbers and T some interval.
The matrix A is a projection matrix. i.e. A^2 = A
First attempt at the problem involved showing that e^{tA} idempotent because of the projection matrix but soon found out that it could not be.
A^2 = A then
(tA)^2 = tA this, I think, is obvious, but then
(e^{tA})^2 = e^{2tA} \neq e^{tA} this is where I stranded first.
Second attempt involved this trick
e^{tA}e^{-tA} = I this will give us
e^{tA}e^{-tA} = I = Ie^{-ta} - Ae^{-tA} + e^{t-tA}A
= (I-A)e^{-tA} + Ae^{t(I-A)}
Now, if I differentiate this
\frac{d}{dt} I = 0 = -A(I-A)e^{-tA} + A(I-A)e^{t(I-A)}
So close, yet so far...this cannot be true cause of the exponential functions. Not unless
-A = I - A by some means.
Any ideas?
Cant you just use the definition of the matrix exponential, i.e.
e^{tA}=\sum_{k=0}^\infty{\frac{t^kA^k}{k!}}
Using the formula A=A² in there should simplify a lot of terms...
You my dear sir are a delight!
e^{tA} = \sum_{n=0}^{\infty} \frac{1}{n!} t^n A^n = I \ - \ A \ + \ e^t A = I \ - \ A \ + \ A \sum_{n=0}^{\infty} \frac{1}{n!} t^n
= I - A + A(I + t + \frac{1}{2!} t^2 \dots \frac{1}{n!}t^n)
Now we know that A^n = A so
\sum_{n=0}^{\infty} \frac{1}{n!} t^n A^n becomes
I + tA + \frac{1}{2!} t^2 A + \dots + \frac{1}{n!} t^n A
This is equivalent to the right side of the equation, so it fits.*victory dance*
:cool:
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
