Exponential of creation/annihilation operators
In summary, the conversation discusses a pdf that explains the coherent state path integral and its use of coherent state resolution. The "hint" given in the pdf is to use the fact that a acts as a derivative with respect to a^\dagger. The conversation also touches on the proof of this fact through induction and its application to any analytic function.
ansgar
516
Hello!
I found on this webpage:
http://www-thphys.physics.ox.ac.uk/people/JohnCardy/qft/costate.pdf
page 1, on the bottom
that
[tex] e^{\phi^* a } f(a^{\dagger} , a ) = f(a^{\dagger} + \phi^*, a) e^{\phi^* a }[/tex]
I have tried to prove this, writing both as taylor series, but the problem is to understand the "hint" :(
that
For the benefit of other readers, this pdf performs a quick derivation of the
coherent state path integral (in which a coherent state resolution of unity is used
between time slices rather than the usual resolutions using momentum and position
eigenstates).
The "hint" is
Use the fact that a acts like [tex]\partial/\partial a^\dagger[/tex], (...),
which refers to this trick:
[tex]
[a, g(a^\dagger)] ~=~ \frac{\partial g(a^\dagger)}{\partial a^\dagger}
[/tex]
as may be shown by induction (perhaps modulo a sign and/or some
factors of i and [tex]\hbar[/tex], depending on one's conventions).
Start with [tex]g(a^\dagger) = a^\dagger[/tex], then progress to
[tex]g(a^\dagger) = (a^\dagger)^2[/tex], to see the pattern,
then prove it for [tex]g(a^\dagger) = (a^\dagger)^n[/tex] by induction.
Then you can extend the result to any well-behaved analytic function.)
HTH.
ah yes now its clear! Thank you
eigenstates).
The "hint" is
[tex]
[/tex]
HTH.
1. What is the exponential of creation/annihilation operators?
The exponential of creation/annihilation operators refers to the mathematical operation of taking the exponential of an operator that creates or destroys particles in quantum field theory. It is commonly used in the study of quantum systems, such as in the creation and annihilation of particles in particle physics.
2. What is the purpose of using exponential of creation/annihilation operators?
The exponential of creation/annihilation operators allows for a more convenient and efficient way of describing the behavior of quantum systems. It helps simplify complex mathematical calculations and provides a more intuitive understanding of the creation and annihilation of particles in quantum field theory.
3. How is the exponential of creation/annihilation operators calculated?
The exponential of creation/annihilation operators is calculated using the Taylor expansion of the exponential function. It involves expressing the operator in terms of its power series and then summing up the series to obtain the exponential of the operator.
4. What are the properties of exponential of creation/annihilation operators?
Some of the properties of exponential of creation/annihilation operators include linearity, commutativity, and associativity. It also follows the general properties of the exponential function, such as the product rule and the power rule.
5. How is the exponential of creation/annihilation operators used in practice?
The exponential of creation/annihilation operators is used extensively in quantum field theory and particle physics to describe the behavior of quantum systems. It is also used in other areas of physics, such as in quantum optics and quantum computing, where the creation and annihilation of particles are of interest.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
