Exponential of creation/annihilation operators
ansgar
Hello!
I found on this webpage:
http://www-thphys.physics.ox.ac.uk/people/JohnCardy/qft/costate.pdf
page 1, on the bottom
that
e^{\phi^* a } f(a^{\dagger} , a ) = f(a^{\dagger} + \phi^*, a) e^{\phi^* a }
I have tried to prove this, writing both as taylor series, but the problem is to understand the "hint" :(
that
For the benefit of other readers, this pdf performs a quick derivation of the
coherent state path integral (in which a coherent state resolution of unity is used
between time slices rather than the usual resolutions using momentum and position
eigenstates).
The "hint" is
Use the fact that a acts like \partial/\partial a^\dagger, (...),
which refers to this trick:
<br /> [a, g(a^\dagger)] ~=~ \frac{\partial g(a^\dagger)}{\partial a^\dagger}<br />
as may be shown by induction (perhaps modulo a sign and/or some
factors of i and \hbar, depending on one's conventions).
Start with g(a^\dagger) = a^\dagger, then progress to
g(a^\dagger) = (a^\dagger)^2, to see the pattern,
then prove it for g(a^\dagger) = (a^\dagger)^n by induction.
Then you can extend the result to any well-behaved analytic function.)
HTH.
ah yes now its clear! Thank you
eigenstates).
The "hint" is
HTH.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
