Expressing F(x,y) as a function of x and y when it is a function of u and v
  • Thread starter Thread starter jacquelinem_00
    Function
jacquelinem_00
F(x,y) is defined by the integral
(x,y)
S [-2uv^2sin(u^2v)]du + [cos(u^2v) - u^2vsin(u^2v)]dv
(2, pi)
Express F(x,y) as a function of x and y, eliminating the integral sign.
**Plus, I added the question as a bmp file, because I don't know how to write it all pretty like you guys do!
*** Also, the S is the integral sign :D
I'm guessing I should let x = uv^2 and y = u^2v.
Well, I know there is some substitution involved, but I honestly have no idea where to start with this question. Any hints would be greatly appreciated! :blushing:
(x,y)
(2, pi)
Are you missing a bracket somewhere in your integrand? As it's written the integral doesn't seem to make sense... I guess I will wait for the .bmp file to get approved before I can help.
That's a path integral in the uv-plane but it does not appear to be independent of the path:
(-2uv^2 sin(u^2v))v= -4uv sin(u^2v)- 4u^2v^3 cos(u^2v)
(c0s(u^2v)-u^2v sin(u^2v))u= -2uv sin(u^2v)- 2uv sin(u^2v)- 2u^3v^2 cos(u^2v)= -4uv sin(u^2v)- 2u^3v^2 cos(u^2v)
are not equal.
Ah, I see now. And it is indep of path, both
\frac{\partial f_u}{dv}=\frac{\partial f_v}{du}=-4uv\sin-2u^3v^2\cos.
so, anyways, Jacqueline, I think it would be easiest to choose a path from (2,pi) to (x,y) that first runs straight up the "v-axis" from pi to y (at fixed u=2). I.e., use du=0 and plug in u=2 to the one integrand which multiplies dv. Now look at the resulting integrand. Is it a total derivative? if so then we are in luck and don't have to work very hard. What do you find?
Next, integrate straight across the "u-axis" from 2 to x (at fixed v=y). I.e., use dv=0 and plug in v=y to the one integrand which multiplies du. Now in this integrand there is a (one dimensional) change of variables that should be obvious. what do you find? Make the change of variables and complete the integral.
Drawing a picture of the u-v plane would probably help you too. label the points (2,pi) and (x,y) and draw the path that you are taking... in fact, you can use any path you like, but I think the problem was probably designed with the boring path I just described in mind. Cheers,
adam
Thank you so much Adam! You're great!
You're welcome. :wink:
Hey Adam! (Or anyone else!)
I think I thanked you prematurely. From reading your response I thought I knew what I was doing, until I tried to finish the question, and realized I was still stuck.
I took your advice and did everything. I fixed u=2 and set du=0. For the first part, I found that my integral was
-(y)
- (pi)
= ycos(4y) - picos(4*pi)
Now this is supposed to be a total derivative? Yikes, I have no idea what it even MEANS!
Then I set dv=0 and I had
- (x)
| [-2uy^2sin(u^2y)] du
- (2)
=ycos(x^2y) - ycos(4y)
What am I even finding here? I cannot wrap my mind around these concepts! I really hate to ask you guys again, but I think all this sunshine this summer has fried my brain! Please help! Thank you!
...I found that my integral was
-(y)
- (pi)
what I meant was that the integrand
<br /> cos(u^2v)-u^2vsin(u^2v)=\frac{d}{dv}(vcos(u^2v))<br />
is a total derivative... but, whatever. it doesn't matter as long as you can do the integral... which you did do, and you did correctly. So the expression you found
<br /> ycos(4y)-\pi cos(4\pi)=ycos(4y)-\pi<br />
is right and it is the first part of your answer. (Oh, btw, I also used cos(4pi)=1)
- (x)
- (2)=ycos(x^2y) - ycos(4y)
Right. That is the correct value of the second contribution to the total value of the integral... so the total value of the integral is the sum of the two parts you found. I.e., the answer is
<br /> (ycos(4y)-\pi) + (ycos(x^2y)-ycos(4y))<br /> =<br /> ycos(x^2y)-\pi<br />
You are welcome again.
