Extracting circuit diagram from charge controller PCB layout
8 replies · 6K views · last reply
lostmind
Dear All
I have been recently started to work with Reverse Engineering technology and I would now like to determine a circuit layout diagram of a charge controller from its PCB Layout.
Can anyone please help me with this one. I have uploaded the PCB design for your reference.
Please note that this is purely a hobby project and I highly discourage commercial personalities business advice.
Thanking you all in advance
  • Printed circuit board copper layout for a charge controller, showing traces, pads and silkscreen labels such as NORMAL, CHARGE, and resistor values including 1K and 470.
you just have to start somewhere at a point and start drawing out the components as a schematic. once everything is drawn out, and checked to make sure you haven't missed any interconnections then you can work on tidying up the schematic into something that looks easy to follow
I have done this so often over the years on substantially more complex ccts than that one of yours
Initially I will draw it out on paper and once I have a reasonable looking layout I will then use MSpaint ( paintbrush) to do the final drawing like you see below so I can store it on the puter for future reference
eg...
Photo of a green and gold double-sided RF circuit board with a Z-Comm VCO module, a Sierracom label reading MADE IN THE U.S.A., and gold-plated microstrip traces.
Hand-drawn style schematic of the Harris Microstar 23 GHz transmitter board, with a connector pin assignment table at top right and a legend for inter-board connectors, through holes, upper and lower tracks and RF stripline.
The first image the actual unit
the second image, a reasonable schematic
This board was particularly difficult as it was double layer
cheers
Dave
  • Hand-drawn style schematic of a Harris Microstar 23 GHz transmitter board, with a title block dated 05/11/04 and a connector pin assignment table listing supplies, clock, data and load enable pins.
  • Photo of a double-sided printed circuit board with a Sierracom label and a Z-Comm module, showing green and gold RF traces and surface-mount components.
Its been one of those 10 year projects to put this unit onto the 24GHz amateur radio band, It may never happen as other ex commercial gear became available that was much easier to convert
here's another example I did some years back...
Top view of a green printed circuit board inside an aluminium case, with surface-mount and through-hole components, several larger power regulator packages, and text reading ASSY 902010 REV, MICROWAVE PULSE CORP.
Schematic of an I.F. Amp and AGC Stages circuit from Microwave Radio Corp., dated 14 Aug 2003, showing SA5209 variable gain amplifiers, LM358 op-amps, and an LM2941 regulator.
its takes some serious concentration magnifier lamp good backlight
but its often worth the effort
cheers
Dave
  • Top view of a green printed circuit board inside an aluminium housing, with surface-mount and through-hole components, two large power regulator packages at the lower left, and printed text reading ASSY 902010 REV and MICROWAVE RADIO CORP.
  • Schematic of an I.F. Amp and AGC Stages circuit from Microwave Radio Corp., dated 14 Aug 2003, sheet 6 of 12, showing two SA5209 variable gain amplifiers, op-amps, regulators and filter networks.
Dear Davenn thank you a lot for your replies...I am working on the circuit schematic...since this is my first one so I am a little bit confused...i made an initial draft last night and want to confirm whether it is correct or not...can you suggest me any ways to perform that ?
thanking you again
post a pic of the layout on here once you have tidied it up, and if I have time or some one else may get a chance to compare it with the PCb layout you gave above :)
Dave
Lostmind, Do you have the actual CAD of the layout or just the image? Can the CAD tool just print a connection report on all the nets and a BOM? Should be fairly straight forward to reconstruct a schematic from that information.
cheers
Dave
You have 'true grit' Dave. I'm very impressed! Much worse than the Guardian Crossword.
Yes, beautiful work Dave! :smile:
Nice indeed. I'm thinking the paint work was the hardest. :devil:
