Extracting eigenvalues from wavefunction
Ichimaru
The Hamiltonian for a rigid rotator which is confined to rotatei n the xy plane is
\begin{equation}
H=-\frac{\hbar}{2I}\frac{\delta^{2}}{\delta\phi^{2}}
\end{equation}
where the angle $\phi$ specifies the orientation of the body and $I$ is the moment of inertia. Interpret this experession and fint the energy levels and egenfunctions of H.
The unnormalised wavefunction of the rotator at time t is
\begin{equation}
\psi(x) = 1 + 4 sin^{2}(x)
\end{equation}
Determine the possible results of a measurement of its energy and their relative probabilities. What is the expectation value of the energy of this state.
I've found the eigenfunctions as
\begin{equation}
\psi_{m}(x)= Ae^{im\phi}
\end{equation}
\begin{equation}
E_{m}=\frac{ \hbar^{2} m^{2} }{2I}
\end{equation}
And m is any positive / negative integer.
But I don't really know how to analyse the wavefunction properly. We have always used the ket approach which is much simpler conceptually. Analagously I would apply the Hamiltonian to the wavefunction in the position representation, and try and factor out the original wavefunction times some number, which would be the relevant energy eigenvalue. But I can't seem to get anything understandable out.
Any help with how to understand getting measurements and their probabilities out of wavefunctions in general would be useful. Thanks.
You can define |m> as your ##\psi_m## if you like, or just use ##|\psi_m \rangle##.
Calculating ##H \psi_m## in the position basis is straightforward here and you directly get the eigenvalue as result you posted.
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
