Extracting Sodium Hydroxide from Soap
Extracting sodium hydroxide (NaOH) from liquid soap is a topic of interest, particularly for testing purposes. It is noted that a solution derived from soap may primarily consist of a mixture of NaOH and potassium hydroxide (KOH), making it challenging to differentiate between the two due to their chemical similarities. Spectroscopy is suggested as a potential analytical method for distinguishing between these bases. However, if KOH is absent in the soap, testing for NaOH directly in the dissolved soap might be a more straightforward approach, eliminating the need for extraction.
g_midford
is it possible to extract sodium hydroxide from liquid soap? i need to test the sodium hydroxide. if it is possible, how would i do it?
Chemistry news on Phys.org
A solution of bases extracted from soap will probably end up primarily as a mixture of NaOH and KOH. As Borek mentioned, it's not really possible to tell the difference between different bases, especially in this case since potassium and sodium in solution are so chemically similar to each other. The only way I can think of differentiating between the two analytically is through spectroscopy.
qalomel, there is no koh in this soap
If there's no KOH and assuming that there aren't any other bases aside from NaOH in the soap, can't you just test the NaOH directly in dissolved soap without extracting it?
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
