SignaturePF
- 112
Which of the following sets of equipment cannot be used to measure the local value of the acceleration due to
gravity (g)?
(A) A spring scale (which reads in force units) and a known mass.
(B) A rod of known length, an unknown mass, and a stopwatch.
(C) An inclined plane of known inclination, several carts of different known masses, and a stopwatch.←
CORRECT
(D) A launcher which launches projectiles at a known speed, a projectile of known mass, and a meter stick.
(E) A motor with a known output power, a known mass, a piece of string of unknown length, and a stopwatch
I eliminated A because that is a fundamental way to measure gravity, as a scale reads normal force. Simply place an object on flat ground where Normal force = mg, divide the known normal force by the known mass, and we have gravity.
I eliminated B since we can use uniform accelerated motion.
Δy = v_0t + 1/2at^2
since v_0 = 0
Δy = 1/2at^2, we also know t, so clearly we can find a
C I believed you could find, I'm not sure why you can't.
D I thought you could use projectile motion equations.
E I'm not sure.
