Factoring algebraic complex expression
The discussion revolves around factoring the algebraic expression ac - bd + adi + bci, which involves complex numbers and algebraic manipulation.
  • Participants explore different factoring techniques, including factoring out common variables and identifying similarities between terms. Questions arise regarding how to manipulate the factors to achieve a desired form.
Participants are actively engaging with the problem, offering insights and corrections. There is recognition of the need for clarity in the approach to factoring, and some guidance has been provided regarding the identification of common factors.
There is a mention of wanting a complete factorization, and participants are navigating the complexities of working with both real and imaginary components in the expression.
Maxo
Factor the expression ac-bd+adi+bci
We can factor the variable 'a' which gives:
a(c+di)-bd+bci
The common factor in the remaining terms is b, and if we also factor out b we get
a(c+di)-b(d+ci)
But this is not the way I want it factorized. I want it to be factored completely. How can that be done step by step?
a(c+di)-b(d-ci)
Do you realize the similarity between the factors (c+di) and (d-ci)? How can you make them the same?
I made a misstake, it should be a(c+di)-b(d-ci). Anyway so you're saying (c+di) and (d-ci) can be made the same. I actually don't see how that could be done? I mean both the real and the imaginary parts of these expressions are different. How are they the same?
Maybe I wasn't very clear with what I meant by "make the same", but what I was trying to convey is identifying the common factor between these two terms. Notice that they differ by a factor of i
For your second step, factor out bi instead of just b. Be more careful with signs and brackets.
Now I see it :)
Is there some rule (algorithm) / procedure to follow when factoring like this?
