How can factoring help solve limit problems involving radicals?
Factoring can simplify limit problems involving radicals by transforming the expression to eliminate indeterminate forms. In the given limit, (x^(1/6)-1)/(x-1), substituting y = x^(1/6) allows for the application of the formula y^6 - 1 = (y - 1)(y^5 + y^4 + y^3 + y^2 + y + 1). This substitution leads to a new limit as y approaches 1, facilitating easier computation. The discussion emphasizes the importance of recognizing that division by zero is undefined, reinforcing the need for proper factoring techniques. Ultimately, understanding these methods can streamline the process of solving limits involving radicals.
Mach
This question is concerning a limit question. I have no problems finding limits but i need to be able to factor this equation. I need to be able to some how get rid of the (x-1)
(x^(1/6)-1)/(x-1)
I ust keep ending up in a loop geting a bigger and bigger radical.
An out of curiosity can 0 be divided by 0?
Nope. Give us the actual limit, there's an easier way.
No, you cannot divide by 0- not even 0! You should know, from a more general formula, that y^6- 1= (y- 1)(y^5+ y^4+ y^3+ y^2+ y+ 1). What happens if y= x^{1/6}?
Then all that's left is to create a new limit as y approaches something. In this case its still 1 but you would need to take the 6th root of the original limit point
For example, if you wanted to do something like the limit as x approaches 8 of: \displaystyle{\frac{-x^2+ 4x^\frac{4}{3}+ x^\frac{7}{8}+ x^\frac{5}{6}- 4x^\frac{1}{2}- 4x^\frac{1}{6}}{x^\frac{2}{3}- 4}}
You would have to again use y=x^(1/6), but take the new limit as y approaches 8^(1/6) or radical 2 of:
\displaystyle{\frac{-y^12+ 4y^8+ y^7+ y^5- 4y^3- 4y}{y^4- 4}}
