Factors affecting the design of an efficient paddle wheel
  • Context: Undergrad
  • Thread starter Thread starter paddlewheel99
    Design Factors Wheel
The discussion focuses on the factors affecting the design of an efficient paddle wheel, exploring various aspects such as paddle shape, size, rotation speed, and submersion depth. Participants are interested in the physics principles involved, including conservation of momentum and Newton's laws, as well as constructing experimental models to test their hypotheses.
  • Some participants suggest that the number, size, and shape of paddles, as well as the rotation speed, are critical factors in paddle wheel efficiency.
  • One participant emphasizes the importance of keeping the hull shape constant while varying paddle designs.
  • There is a discussion about the relationship between paddle submersion and efficiency, with some arguing that less submersion leads to more efficiency but slower speeds, while others contest this view, suggesting that full submersion may be necessary for effective thrust generation.
  • Concerns are raised about the shape of paddles, with some proposing that concave paddles may hold more water and thus be more efficient than flat paddles.
  • Participants inquire about the relationship between angular momentum and linear momentum, questioning whether all angular momentum can be converted to linear momentum.
  • There are requests for clarification on how to calculate the efficiency percentage of a paddle wheel, with suggestions that it may involve output/input power calculations.
  • Some participants discuss the potential complexity of adding a shroud to the paddle wheel design, with differing opinions on its utility.
Participants express multiple competing views regarding the effects of paddle submersion on efficiency, and there is no consensus on the optimal paddle shape or the best approach to calculating efficiency. The discussion remains unresolved on several technical aspects.
Participants note the need for further research into the physics behind paddle wheel design, including rotational motion and torque, and highlight the importance of defining research questions that are narrow enough to allow for in-depth exploration.
paddlewheel99
I'm a student undertaking a challenging physics project. My project is based on the Factors affecting design of an efficient paddle wheel.
Until now the factors i could think about are:
-Number of paddles
-Size and shape of paddles
-Rotation speed of paddles
Since my object of study is paddle design, I have decided to keep the hull shape constant for all possible designs.
After doing heavy research and study I have understood that the motion of a paddle wheel boat will obey the law of conservation of momentum. As the paddles push the water in the backward direction, the boat would be propelled forward as per the above law. An effecient paddle wheel would be one that translates into maximum forward motion for a perticular amount of energy spent.
I would appreciate your inputs on
1. Explanation on the physics aspect
2. Constructing a experimental model
-Number of paddles
What paddle shapes have you found so far in your research? What have you found so far about the difference in efficiency between a paddle wheel and a propeller?
Consider the diameter of the wheel.
how much it is submerged underwater.
hint: less submersion is more efficient but slower
Why would this follow? The paddle wheel is only doing useful work when it is submerged. More submersion should be necessarily more efficient; this is one of the principle advantages of the (fully submerged) screw.
It's no different than paddling a kayak manually. You maximize efficiency by submerging the entire paddle. Sure, submerging half the paddle let's you move the oar more quickly, but you move less mass, generating thrust less efficiently. Velocity is bad (wasted energy), momentum is good (pushes the boat forward).
''What paddle shapes have you found so far in your research? What have you found so far about the difference in efficiency between a paddle wheel and a propeller?''
Actually my only aim is investigating factors affecting design of paddle wheel (to make it efficient) I will conduct all the experiments later, first i want to get all the physics theory and hypthesis in order.
It is correct that the more you submerge the paddlewheel in water, it will become more efficient. Which i did not think of, so i would have to keep this factor constant, right? The material of the paddlewheel and paddles should also be same?
Now i am confused, can anyone suggest me what should be my research question (it should ideally be narrow) Mine so far: Investigation of the factors affecting design of a good efficient paddle wheel, or should i investigate only one factor which will allow me to write atleast 4000 words.
Also:
Newton's Laws of Motion, namely his third law which essentially states that for every action (a) there is an equal and opposite reaction(r) . In this case the paddle wheel is (a) and movement of boat is (r). What other forces would act on the boat?
Can anyone give me more physics behind this topic in terms of:
rotational motion, angular speed, torque, etc.
Will the angle or something come into play? (i am confused about this part)
Well, with a flat paddle, as the water is pushed it is compressed and will tend to roll to the sides and away from, a flat paddle.
A concave paddle will also compress the water, but tends to "hold" more water volume.
Consider this "l" versus this ")" or this "]"
The obvious case is if the paddle wheel is completely submerged, then it only generates a torque and no net linear force, since you have equal and opposing forces on the paddles opposite from each other on the wheel.
For partial submersion, there's some ideal point where the paddles don't waste too much energy pusing water downwards at entry, and upwards at exit. Too little submersion and the paddles don't move enough water.
pallidin said:
Well, with a flat paddle, as the water is pushed it is compressed and will tend to roll to the sides and away from, a flat paddle. A concave paddle will also compress the water, but tends to "hold" more water volume. Consider this "l" versus this ")" or this "]"
A "V" shaped paddle would have an issue with slowing down a boat, not sure if it's more efficient in forrwards mode.
Just trying to study the relationship between angular momentum and the linear momentum for the paddle wheel. Will all the angular momentum be transferred to linear momentum, can there be any equation linking it (specific ref. to the paddle wheel)
All the angular momentum might not be transformed into linear momentum.
Since you are studying efficiency of paddle wheel out of curiosity I would like to know how to work out the efficiency percentage of paddle wheel. In many boat design forums they mention the efficiency in terms of percentage. How to calculate this percentage.
Can your paddle wheel have a shroud?
I imagine it would be the usual output/input power, where power = F*V.
Articulating blades?
So if we want to calculate input power do we derive force value from torque. Also what velocity do we consider. Should it be velocity with which water is pushed back.
I hope someone clarifies this power and efficiency calculation.
I don't think having a shroud will help. It will make the project even more complicated. It would be better to stick to calculations of power.
The difference is that, with just one kayak paddle, you waste time getting back to the beginning of your stroke. With a wheel, you can arrange to have at least one paddle in the water all the time. And there would be a limit to the practical size of a kayak paddle.
I could ask why it has to be a wheel. What about paddles mounted on a belt which dips into the water and then takes each paddle back along the whole length of the ship? Losses due to entry and exit would be reduced significantly. Never had those on the Mississippi, did they?
Lots of maintenance problems though.
Okay, so now i want to study one factor related to paddles in detail: no. of paddles, or shape of paddles or rpm of paddles. Which factor do you think i should study, which will allow me to give detailed argument and discussion on physics concepts
I would think that the number of paddles might be a good place to start.
I forget if we covered this already, but an even better project would be to compare the efficiency of a paddlewheel to a propeller, given the same power input...
Honestly I think you should study classical mechanics and fluid dynamics first, then you'll be able to solve the paddle wheel issue on your own.
The benefit is that you can use your physics knowledge for the rest of your life as well as for this project.
11K
  • · Replies 26 ·
  • · Replies 20 ·
12K
  • · Replies 24 ·
  • · Replies 138 ·
35K
  • Poll Poll
