Failure to see the validity of an approximation to DiffEq.
The discussion centers on solving the Schrödinger Equation for a harmonic oscillator using a power series method, specifically analyzing a recursion formula for large values of j. Participants express confusion over the approximation of coefficients and the relationship between the constants and the function h(y). The approximation a_j ≈ C/(j/2)! is confirmed as a solution to the recursion relation, with further clarification provided on how this leads to the expression for h(y). The conversation emphasizes the need for explicit steps to understand the derivation of these approximations. Overall, the thread seeks to clarify the mathematical relationships involved in the solution process.
davidbenari
The following comes from Griffiths Intro. to QM (2nd Ed) page 53.
We want to solve the Schrödinger Equation for the harmonic oscillator case using a power series method. The details aren't important but you want to solve
##h''(y)-2yh'(y)+(K-1)h=0##
whose recursion formula is
##a_{j+2}=\frac{2j+1-K}{(j+1)(j+2)}a_j##
Griffiths wants to analyze those solutions which aren't normalizable so he considers large values of ##j##. The recursion formula becomes (to large ##j##)
##a_{j+2}=\frac{2}{j}a_j##
Which makes sense, but then he says that this has the approximate solution (from now on is the part where I don't understand)
(1) ##a_{j}\approx \frac{C}{(j/2)!}## where C is a constantconsidering large ##y## we get that
(2) ##h(y) = C \sum \frac{1}{(j/2)!}y^j = C \sum \frac{1}{j!}y^{2j}##So, I consider (1) mysterious and the second equality of (2) ( ##C \sum \frac{1}{j!}y^{2j}##) mysterious as well. Anyone care to help me showing the intermediate left-out steps?
Thanks.
Mathematics news on Phys.org
Hi david:
I can help with the first question, but there is something I don't understand regarding your second question.
Regarding
Just confirm that (1) is the solution to the recursion equation
aj+2=2/j aj
by substituting (1) and a modified (1) for j+2 into the above equation.
I hope this is helpful.
Regarding the the second mystery, I don't understand the relationship between the constants aj and the function h(y) of the differential equation.
Regards,
Buzz
Buzz:
I guess I forgot to mention that we're supposing the solution ##h(y)## is of the form ##h(y)=\sum a_j y^j##. I.e. a power series.
aj+2=2/j ajby substituting (1) and a modified (1) for j+2 into the above equation.
I'm relatively confused about what you said here. It would be helpful if you could be more explicit. Specifically I'm not sure how this solves the recursion relation.
Thanks!
Hi david:
aj+2 = (2/j) aj
aj ≈ C/(j/2)!
aj+2 ≈ C/((j+2)/2)!​
Now one needs only to show that
C / ((j+2)/2)! ≈ C (2/j) / (j/2)!​
This can be more easily seen by cancelling the Cs and examining the reciprocals.
((j+2)/2)! ≈ (j/2)! / (2/j) = (j/2)! × (j/2)
((j/2)+1)! = (j/2)! × (1+J/2) ≈ (j/2)! × (j/2)​
Cancelling the (j/2)!s gives
(1+J/2) ≈ (j/2)​
which is a reasonable approximate equality for sufficiently large j.
Regards,
Buzz
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
